4" drivedhaft with 9" rear axle
Hello,
I have a 9" currie rear axle.
From some weeks i have vibrations under my seat starting at 50- 55mph and growing with speed
I tought it was pinion angle , but corrected alignement and rear axle centering.
I checked everything and think it is the driveshaft...
I planned installing a 4" diameter aluminium driveshaft.
do someone has one ?
any clearance issue ?
If you have any idea , advice, don t hesitate
Thanks for your help
Marc
Marc
Car: 1991 camaro Z28
Engine: Forged 370" LS turbo s488
Transmission: Built 4L80e FTI converter
Axle/Gears: MWC 9" 35 spline 3.25 gears
Re: 4" drivedhaft with 9" rear axle
Hello,
Marc
Marc
Engine: LG4 / turbo LQ4
Transmission: 700R4 / 4L80E
i have a 3" Denny's nitrous ready driveshaft in my '84 TA. it's behind a turbo 370 LQ4 and 4L80E. rear is a Moser Ford 9". i just got the car running before winter so i've only been able to drive it around the block a few times, but so far so good.
What are you trying to do with the car that you figure you need that 4-5 lb savings?? Try calling a reputable company and ask them their thoughts as to which direction to go. If you're looking for those weight savings I'd scrap the idea of aluminum and go carbon fiber
What torque arm are you using? I have the BMR Trak Pak. Between that and my 3” Magnaflow catback there’s not a lot of room left in the tunnel. I’m not sure a 4” driveshaft would fit with my setup.
Car: '91 GTA
Engine: 421sbc
Transmission: Powerglide
Axle/Gears: Ford 9" with 3.89
Engine: 4++,350 & 305 CIs
I run a old spicer/lingenfelter 3.5" aluminum ds with my moser9"
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
I got a 3.5” moly and its fairly close to the torque arm in some spots. I got the midwest rear and torque arm package which uses a separate crossmember, not off the trans crossmember to mount the trq arm so its a but shorter. 3.5 fit good but its abit tight in there.
i would think 4” will fit tho.
I can't comment on the fitment of a 4" aluminum driveshaft although aluminum to me is not the way to go. But that's application specific.
Pat's Driveline is in BC (as well as the rest of Canada) and they've built several custom shafts for us (back in the day). Never a failure despite some beefy output (from customers not me specifically). There's a 3 1/2" steel shaft in the BBC TA with room to spare if that's of any relevance.
https://www.google.com/search?rlz=1C...&bih=937&dpr=1
Car: 89 Iroc-z
Transmission: TH400
Guess i shoukd ask how much power do you need to hold? Have you considered carbon fiber?
