TKX clutch assembly question
Old Mar 11, 2023 | 08:07 PM
Noahshenk's Avatar
Car: 1989 Base Firebird
Engine: fuel injected 2.8L V6
I plan on swapping a TKX 5 speed to go behind my 1977 4 bolt main 350, which I believe is a two piece rear main seal. What is a good streetable flywheel, clutch, and pressure plate combo for my application? thanks!
Old Mar 12, 2023 | 12:42 PM
MDDAWG's Avatar
Car: 91 z28
Engine: 387 SBC
Axle/Gears: 3.73 eaton posi
Re: TKX clutch assembly question
I just installed a TKX in my camaro with a sbc two piece rear main seal I used a Ram zero ballance billet steel flywheel and Ram single disc clutch disc and pressure plate , with hydraulic t/o bearing, it works great . The engine makes 540 hp at the flywheel
Old Mar 12, 2023 | 03:09 PM
Noahshenk's Avatar
My numbers will be a touch below that, but a little overkill will give me some wiggle room to play if I decide to add some more! Do you have the part numbers for those parts? Thanks!
Old Mar 12, 2023 | 03:31 PM
MDDAWG's Avatar
Car: 91 z28
Engine: 387 SBC
I should have I will look and post them up for you
Old Mar 14, 2023 | 12:55 PM
MDDAWG's Avatar
Car: 91 z28
Engine: 387 SBC
Here is a couple of numbers. the flywheel I used was the Ram 22 lb. one part #1501LW. if you want the 30lb. one it is #1501. The clutch I used is a Ram 88764 HDX. I don't know if you are going from an Auto to a manual But if you are swaping , you might take a look at Hawks TKX conversion kit , it has everything you need. Have fun , mine works awesome.
tonythetoad
Oct 8, 2023 03:57 PM
RK82
Aug 20, 2009 12:03 AM
Truckedup
Oct 28, 2008 06:02 AM
nivek82z28
May 14, 2007 04:39 AM
scottland
Feb 9, 2003 08:23 AM
