pedal springs?
Car: 1990 LS6 Camaro
Engine: LS6 with a cam basically
Axle/Gears: 4th gen 3.42 rear
pedal springs?
I took the pedals out of my car to replace the bushings (I have the older Pre-87 manual pedals) and I didn't notice any return springs on the pedals. Does this assembly not use them? If it should, can someone point me to where I might acquire some. Thanks.
Car: 1983 Z28
Engine: 385 Fastburn
Re: pedal springs?
No return springs on the pedals.
The clutch pedal returns via a spring and pressure in the slave cylinder.
The brake pedal returns via pressure from the master cylinder.
The gas pedal returns via return spring on the end of the throttle cable.
Re: pedal springs?
Thank you for the info. I just wanted to make sure my pedals are ok after I took them out.
Car: 1983 Z28
Re: pedal springs?
