1997 transmission
Old Sep 8, 2023 | 01:34 PM
dynamak's Avatar
1997 transmission
1997 4l60e if i leave the rpms below 2000 it shifts ok if i go above 2000 it slips if i put it in 3rd once it shifts to 3rd it will keep reving and seems to be fine Thank you for your time
Old Sep 8, 2023 | 07:17 PM
ratfink6923's Avatar
Car: 15 Ram, 88 IROC, 92 RS
Engine: 5.0
Axle/Gears: 3.42 (4th Gen)
Re: 1997 transmission
97 trans behind what engine? OBD2? Any trans dtcs?
Old Sep 9, 2023 | 09:01 AM
dynamak's Avatar
350 no codes
Old Sep 9, 2023 | 10:02 AM
Since this is a forum specifically devoted to 82-92 Camaro/Firebird ONLY, not just a random "tech" Q&A about any/all random vehicles, you'll probably get more (any) results if you go to a forum for 97 whatever vehicle you have; truck maybe.
Old Sep 11, 2023 | 10:36 AM
antoine's Avatar
Car: 1988 camaro z28,1997 camaro lt1
Engine: 355 afr 195 heads,tpis big mouth
Transmission: 700r-4 built by me 3-4 z pack
its going to need a rebuild 3-4 clutch pack is gone
Old Sep 12, 2023 | 07:24 PM
vorteciroc's Avatar
Top Answer: 1
I am confused...
It slips in 2nd-Gear, but does not slip in 3rd-Gear?
Does it slip in any other Gear.
Fortunately the THM700-R4 and 4L60E Family Transmissions are near identically internally (excluding the Valve-Body... and it is even very similar in many ways).
Please clarify when there is Slipping, and when there is Not.
If it Only slips in Second-Gear, the 2-4 Servo-Pin Clearance may be excessive from Band wear/ mileage/ age.
Johny2234
Apr 11, 2016 10:07 PM
graphicideas1
Apr 15, 2006 06:00 AM
JWKbride
Aug 15, 2004 09:16 AM
86IROCTHD
Jun 2, 2002 05:05 AM
