Transmission part. What is it & where does it go.
Old Sep 13, 2023 | 04:32 PM
BBCSwap's Avatar
Engine: SBC Dart 400 Holley 750 Carb
Axle/Gears: 28 spline 323 gears
91 Z28 700R4. Transmission disassembly. Transmission on side upside down. When I pulled out the low/reverse clutch assembly I heard it fall and it was laying right in front of the low/reverse piston. It is slightly concave, (running up & down) at this view. Only one shiny mark on it as seen. I have looked at every diagram I can find but none of them show this part neither does any utube I looked at. Any ideas??? Do I need it? If so how is it positioned?
Old Sep 15, 2023 | 08:26 AM
BBCSwap's Avatar
Re: Transmission part. What is it & where does it go.
Has anyone ever seen a part like this? Any info at all would be helpful & appreciated. Thanks
Old Sep 15, 2023 | 09:41 AM
ratfink6923's Avatar
Car: 15 Ram, 88 IROC, 92 RS
Engine: 5.0
Axle/Gears: 3.42 (4th Gen)
https://www.chevytalk.org/fusionbb/s...php?tid/20728/
Old Sep 15, 2023 | 10:14 AM
BBCSwap's Avatar
That sounded like it so I googled "case saver" THAT'S IT. Thank you so much. No just to figure out how it's positioned. I will be talking to Pro Built in a week or so and will ask him about it and about the anti clunk spring. Thanks again.
Old Sep 15, 2023 | 10:24 AM
Engine: 5.0
You're welcome, sorry it took so long. I read your post last night before I fell asleep and forgot about it until this morning
Old Sep 15, 2023 | 11:42 AM
BBCSwap's Avatar
I found where it goes. There's a mark on the case. It lays right in there just as nice as can be. Thanks again.
Old Sep 17, 2023 | 10:02 PM
Pro Built Automatics's Avatar
This is one of three different versions of what is called a "case saver". This takes the place of the "anti clunk" spring. This should only be used when the aluminum case lugs are very worn.
Old Sep 19, 2023 | 06:31 PM
vorteciroc's Avatar
Top Answer: 1
Post an Image of the Empty Case, so we can see the Case Lugs.
-If the Lugs are Bad, time for a new case.
-If the Lugs are good, time to find an Original Anti-Clunk Spring.
Those Case Savers should only be used as a Temporary "Band-Aid" to keep the Vehicle Going until the next Transmission Rebuild.
Old Sep 20, 2023 | 07:53 AM
BBCSwap's Avatar
The first pic (right side of case) is the worst by far but I think a file will take out the marks. The left side are light marks. And the bottom is barely noticeable.
Old Sep 20, 2023 | 05:52 PM
vorteciroc's Avatar
Top Answer: 1
My eyes are not the greatest... so help me here...
I see some grooving from the Steel-Plates of the Low-Reverse Clutch (Not terrible if I see it correctly).
The "Case-Saver" is for Case Lug Wear and Tear in the area of the Cast-Iron Support with the One-Way Roller-Clutch.
(Look good from what I can see).
I would probably do some clean-up/ smoothing, and Use the OEM Spring.
Let some others look at the Photos too, and share their opinion
Old Sep 20, 2023 | 06:08 PM
BBCSwap's Avatar
I was hoping you'd say that. I did some filing on areas that needed it and they look pretty good. Like he said, more opinions wanted.
gt4373
Aug 3, 2022 11:06 PM
gt4373
Mar 23, 2022 11:16 PM
gt4373
Sep 11, 2021 11:05 PM
gt4373
Aug 12, 2021 12:07 AM
gt4373
Feb 27, 2020 11:06 PM
