1-2 Accumulator: Transgo Jr springs or Sonnax pinless piston?
Car: 1986 Pontiac Firebird Trans Am
Engine: 305 Tuned Port Injection
Transmission: The famous 700R4
Axle/Gears: No idea
Hi,
Finnally, I'm installing my Transgo shif kit Jr and the Sonnax pinless pistons in the 1-2 and 3-4 accumulators. I did much searchs and it seems orange + blue Transgo springs kit are uncompatibles with the Sonnax pinless piston for the 1-2 accumulator.
Since I should choose one of the 2 alternatives for the 1-2 accumulator, which one could you suggest?:
a).- Use the Transgo Jr solution with the aluminum piston that I already have, with the pin + orange and blue springs, or
b).- Use the Sonnax pinless piston with the original spring
My car has stock engine 305 TPI and stock transmission 1986 700r4, with stock 9 bolts BW diff. 3.27. It's for STREET use.
Also, when I removed the servo, I found the orange return spring broken.
I have 2 alternatives made at a local shop:
1.- One of 30 mm. long (original is 28.5 mm.) with 3 turns and
2.- Another 40 mm. long with 4 turns, much stronger than the previous one.
Which one would you recommend I install?
The servo is also stock and will have the spring that comes in the Transgo Jr kit incorporated into the piston.
Thanks for any advice
Denis V.
Denis V.
TheMagikMan
Sep 19, 2022 09:30 AM
GTA Sammy
Sep 11, 2007 07:54 AM
