Driveshaft / Tail shaft angle
Old Feb 25, 2024 | 11:17 PM
anesthes's Avatar
TGO Supporter/Moderator
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
This is an LS swap but using an SBC bell housing and T5. I think my engine/transmission is angled too far to the right (passenger) side. The weight on the driveshaft rubs the safety loop now, which it didn't before with the SBC.
I had some trouble trying to find a phot of this exact angle for reference. Anyone have one that they can compare? Thanks!
Old Feb 26, 2024 | 08:37 AM
OrangeBird's Avatar
Car: 1989 Firebird
Re: Driveshaft / Tail shaft angle
Hi Anesthes,
It does look off (to the right) to me as well. I know it may sound simplistic, but I'll bet a contractor's chalk line, attached at the very center of the differential yoke and centered perfectly at where the tailshaft housing meets the transmission, would reveal what we're both seeing.
Old Feb 26, 2024 | 08:39 AM
anesthes's Avatar
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
Hi Anesthes,
Good point, in theory the line should be dead center the whole way down the driveshaft, right? Good idea!
Old Feb 26, 2024 | 01:23 PM
Looks "off" to me as well.
I'd just slot the single hole in the crossmember about ½" or so toward the driver's side. You can use the casting parting line in the transmission case as an approximate guide. Slide the trans side to side and tighten it up wherever everything fits the best.
Old Feb 26, 2024 | 01:40 PM
anesthes's Avatar
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
I actually had two problems. It was angled too far to the passenger side, and it was up too high. I ended up loosening up the adjustable LS engine mounts, then took the two piece crossmember apart and welded the slotted part directly to the longer part. This gave me about 1/2" of drop to allow me to use a normal poly mount. Seems better now. Need to highway test it for vibrations. I have enough adjustment now that I should be able to move it around as needed.
tommy64red
Jun 26, 2014 08:43 AM
daturbosix
Dec 4, 2005 11:51 AM
Cronic3rd
Mar 2, 2004 07:27 AM
Z28chrismac
Jan 10, 2003 10:22 AM
12sec305
Apr 30, 2002 08:53 PM
