Need Posi Unit
Old Jan 22, 2002 | 08:18 PM
RamAirZ's Avatar
Car: 1999 Camaro Z28
Engine: 5.7
Need Posi Unit
Hi, does anyone know where I can get an aftermarket replacement posi unit. I was looking into Auburn's unit, but was wondering if there is anything that can just be used as a replacement. Also, with the auburn unit, do I still need to install the gears into it, or does it come with them. Thanks alot.
Old Jan 22, 2002 | 08:59 PM
Pukka's Avatar
From: Where the chicks absolutely LOVE the V-8 rumble!
Car: 92 RS - Fully Restored w/Custom Int
Engine: LO3 with some mods
Axle/Gears: 3.42 Richmond
SLP has the best deal going with a take-off posi @ $99.
Most aftermarket posi's are 3-series, so unless you have 3.23 gears or higher you will need new gears with the posi.
Old Jan 22, 2002 | 09:03 PM
RamAirZ's Avatar
Engine: 5.7
OK, thanks alot. I will look into the SLP deal. I'll probably end up going with 3.42's or 3.73's. Thanks alot.
Old Jan 22, 2002 | 09:12 PM
RamAirZ's Avatar
Engine: 5.7
ok, looked at the site, can't find it anywhere. Can you direct me, thanks alot.
Old Jan 23, 2002 | 12:07 AM
RamAirZ's Avatar
Engine: 5.7
Think I found it, is it the Zexel-Torsen OEM differential. You said this is a posi unit right. And since mine is an 88 it says I will have to change to 28 spline axle's, how hard is this to do. Thanks alot.
Old Jan 23, 2002 | 03:59 AM
Jza's Avatar
Jza
Not hard, you gotta pull the axles anyway...
92projectcamaro
Dec 8, 2015 12:25 AM
loud91rs
Oct 5, 2015 10:05 PM
92projectcamaro
Sep 29, 2015 07:07 PM
tattmann
Sep 27, 2015 05:20 PM
ironbmt
Sep 27, 2015 06:00 AM
