I rebuilt my transmission myself and now I don't have drive
Old Mar 31, 2024 | 03:11 PM
Riley w's Avatar
Car: 1986 bitchin camaro iroc-z
Engine: 305 tpi
I know that might sound like I'm just shitty at building transmissions but I have reverse and I read that it takes more pressure to activate reverse than drive but I don't know if I believe it. I was testing it on the lift and when I first put it in drive I heard it try to activate and it spun the tires for a split second but after that it just dipped in rpm and didn't spin the tires at all. if anyone has had a similar experience I would love to hear how you fixed it thank you. any help would be greatly appreciated. I forgot to mention it is a 700r4 1986.
Last edited by Riley w; Mar 31, 2024 at 03:12 PM. Reason: I forgot some information
Old Mar 31, 2024 | 08:37 PM
Aaron R.'s Avatar
Car: 1985 Z28
Engine: 305 LG4
Re: I rebuilt my transmission myself and now I don't have drive
I don't have an answer for your problem, but I applaud you for diving in, getting your hands dirty, and trying to learn and do something for yourself. I'm sure you will get some great advice on this forum.
Old Mar 31, 2024 | 09:41 PM
vorteciroc's Avatar
Top Answer: 1
Does the Vehicle move under it's own power in any Forward Transmission Range (3rd, 2nd, 1st) ?
It moves in Reverse?
Does it hold in the Park Position?
Old Apr 5, 2024 | 07:53 PM
c-137's Avatar
Car: 85 t/a
Engine: 5.0 tpi
Is the fluid full?
Old Apr 6, 2024 | 01:39 AM
maroe624's Avatar
Car: 92 Z28 Clone
Engine: Vortec 350
Axle/Gears: 3.23 Torsen
By rebuild what do you mean? What was replaced? Did you bench test the pump with the input and reverse drum assembled? Most likely the sealing rings on the input drum or valve body issue or pump is shot, could be anything. I have fully rebuilt 2 4l60/700r4s and one 4l60e and never have had an issue. You cannot rush this type of job, it must be perfect. The 86 700r4 needs to be scrapped and you need to source an 89+ 700, Sorry to be the bearer of bad news but you will have to pull it and take it apart again and transplant all your parts into a newer trans.
Old Apr 6, 2024 | 01:35 PM
Riley w's Avatar
Engine: 305 tpi
yes the car moves under its own weight in reverse and holds park but it does not have any forward gear but when I first put it in gear the tires moved a little but then lost all power
Old Apr 6, 2024 | 01:38 PM
Riley w's Avatar
Engine: 305 tpi
by rebuild I mean I was driving one day and the spray gear in the back of the trans blew up completely but didn't hurt the case but while I was in there I put in new clutches and steels but other than that everything is as it was the job was not rushed and I did test the pump and I vacuum tested and air tested through the entire build
Riley w's Avatar
Engine: 305 tpi
yes the fluid is full
Old Apr 9, 2024 | 10:30 PM
bottledpower's Avatar
Car: 85 IROC
Transmission: 700 r4
Sprag might be backwards
Old Apr 9, 2024 | 10:35 PM
Car: 85 IROC
The early 700 r4s can be updated easily.
Old Apr 10, 2024 | 02:41 PM
vorteciroc's Avatar
Top Answer: 1
Line Pressure readings are need next for further Diagnosis.
The Forward Clutch is not Holding (Low Pressure and/ or burn Clutches).
TBI89Formula
Mar 13, 2007 12:20 PM
Camaro-please?
Nov 15, 2006 06:23 PM
IROC'N
May 27, 2004 05:58 AM
koolcamarodood
Aug 8, 2002 03:32 PM
91Z28
Apr 14, 2002 01:34 AM
