Stupid ?
Old Aug 6, 2002 | 10:31 PM
koolcamarodood's Avatar
Stupid ?
Ok this might be the most stupidest quiestion but i need to know, Which one is Drive , the one with the square around it, or the one before the 2nd
Old Aug 6, 2002 | 11:05 PM
Zirtbow's Avatar
The one with the square around it.. i think
like this
R
N
D <--- that one
D
Old Aug 6, 2002 | 11:50 PM
Kj Rockz's Avatar
From: Mililani, HI USofA Search Posts: 2848.............. Whore Posts: 47.................. Magical Whore Posts: 1
Car: 91 Camaro 77K
Engine: 3.1 Vslick
|-P--|--Park
|-R--|--Reverse
|[D] |--Overdrive
|-D--|--Drive
|-2--|--2nd
|-1--|--1st
Old Aug 6, 2002 | 11:51 PM
89RSOwner's Avatar
uh.........
The "D" with a square is "overdrive"
The "D" without the square is "Drive"
Old Aug 7, 2002 | 09:01 AM
GhostRider84's Avatar
And....
You should take care of your Overdrive (square D) 'couse its only got 2 dinky little clutches in it - easy to tear up.
Old Aug 7, 2002 | 10:23 AM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Second gear would probably die before 4th; the two gears share the same band. 4th doesn't see too much power, but 2nd will.
Old Aug 8, 2002 | 03:32 PM
confucius101's Avatar
"And....
You should take care of your Overdrive (square D) 'couse its only got 2 dinky little clutches in it - easy to tear up."
how do you know if there shot?????
djmarch
Oct 2, 2015 10:41 PM
83ho87gn
Sep 26, 2015 08:49 PM
spartanreaper
Sep 25, 2015 07:22 PM
83ho87gn
Sep 24, 2015 08:58 AM
gta892000
Sep 16, 2015 12:37 AM
