Cluch Master Cylinder Shaft Questions
I'm thinking about using an 88 Camaro clutch master cylinder on my project (not an 88 Camaro!) I see from other posts that the master cylinder mounts low on the firewall, on the foot area. Does this mean that the pushrod is at a downward angle? Also, where can I find a template for the clutch master cylinder firewall mounting?
Thanks in advance for your help.
Car: 85 Berlinetta
Axle/Gears: 10 bolt 3.42 with Torsen posi
Engine: LT1, L400
Transmission: ZF6, T5
Axle/Gears: 3.45, 3.31
Re: Cluch Master Cylinder Shaft Questions
The master is pretty much level....not pointed "down".
DOH! ^That was bad info; it IS at a downward angle. My bad.
I made a template out of card board. I don't have a drawing but someone may.
spills
Jun 17, 2008 09:15 PM
berlinettakid
Oct 3, 2005 03:06 PM
