1982 Pontiac Tran am th200 to th350 help
Old Aug 21, 2024 | 03:24 PM
VinylPunk117's Avatar
Car: 1982 Pontiac Tran am
I need help with some figure out like just tell me dummy way of what I need please
it’s got the 305 engine with the th200c transmission that am going to swap the trans out with the TH350 but I’m having hard time figuring out the different splines and what the **** to do…
the stock is 26 spline but the th350 is 27?
doni just change the rear yoke or what?
explain to me cause I need help
Old Aug 21, 2024 | 03:56 PM
Re: 1982 Pontiac Tran am th200 to th350 help
350 and 200C have the same splines. Not sure where you're going with "rear yoke" and all that.
One of the 350 lengths is the same as the 200C. Can't recall after all these years butt one of the 3 is, although I'm pretty sure it's not the long one. If you get the right one (the same length as your slushbox), everything all just bolts up and works, including your drive shaft, except for the torque arm. You'll need to either find one of the brackets to support the stock TA that's been discontinued for about 25 yrs or so now, bearing in mind you ARE working on a car that's 43 yrs old this month; or get one of the aftermarket crossmember/TA setups that handles that all on its own.
Old Aug 21, 2024 | 05:48 PM
Firechicken82's Avatar
Car: 82 TA
Transmission: Magnum f
Axle/Gears: Ford 9 w 4.11
I did the swap 25 yrs ago. The 350 bolts in. The stock shaft worked. The issue is the shift linkage being a little off and the torque arm mount. You could fab up a mount or just get a crossmember that has a torque arm mount on it (the better move). As far as the shifter, we got an adjustable cable and altered the mount a little. All in all it's pretty easy.
Old Sep 9, 2024 | 02:32 AM
BethParker's Avatar
Thanks for the advice.
Spoiler
Old Sep 9, 2024 | 09:10 AM
72buickgs's Avatar
Car: 1984 Trans AM
Transmission: 700-4r
If I remember my transmission mechanic told me that the TH200c was junk.
Old Sep 9, 2024 | 12:07 PM
dmccain's Avatar
Car: 89 Firebird
Engine: 355 TBI
They arent a th350 or 400 for sure but they can be built. I had one built for my Monte Carlo it held up and had a nice shift kit in it.
Old Sep 9, 2024 | 12:11 PM
The 200C is junk. Its strongest weeeeekness is lack of any kind of decent center support. It was never made to handle more than about 200 ft-lbs of torque, and even that, only very gently applied.
Not at all the same as the 200-4R that came in MCs later on.
Old Sep 11, 2024 | 03:28 PM
vorteciroc's Avatar
Top Answer: 1
Less the Over-Drive Section, the THM200-4R is essentially Identical to the THM200/ THM200C.
They are horrible in Stock form...
But surprisingly have had excellent aftermarket support to allow for 1,000+ HP Builds.
Old Sep 11, 2024 | 04:16 PM
Car: 82 TA
I had a th200 in my 82 when I first got it. It had some kind of shift kit I think. It held up really well to the raging 145hp that car put for 136k miles.
seriously though, if it's a fairly stock early car a rebuilt th200 is probably fine. It wouldn't be my choice but it should work.
Old Sep 11, 2024 | 04:38 PM
T.L.'s Avatar
Car: '83 Firebird (T/A Clone)
Axle/Gears: 10-bolt/3.73 ..
Which among the 200 and the 200C is for V-6 and V-8 (just curious)?...
Old Sep 12, 2024 | 07:47 PM
vorteciroc's Avatar
Top Answer: 1
I am not sure that I follow.
Are you asking if a particular THM200/ C is a better candidate for use with a V6 or V8, such as one from a particular model Vehicle?
If that is indeed what you are asking; No there are no "Performance" Variants akin to the Variants of the THM200-4R.
Old Sep 12, 2024 | 08:25 PM
T.L.'s Avatar
No, I am asking which one bolts to a V-6 and which one bolts to a V-8. I had one for a V-6 decades ago and was told it would not fit a V-8, so I got rid of it...
Old Sep 12, 2024 | 08:59 PM
8t2 z-chev's Avatar
Car: '82 z28
Engine: L83 5.7
Transmission: 700r4-1985
Axle/Gears: 3.42 posi
I recall finding a 200c in a 1984 G-body Regal with a 3.8 Buick in front of it,so probably Chevy,BOP and 60* versions .
Randy82WS7
FAQ Board
Jun 18, 2013 09:58 AM
caleb87irocz
Jan 3, 2011 09:48 AM
rayar
Oct 8, 2010 02:03 AM
ranger77
Oct 17, 2009 01:35 PM
