T5 T56 flywheel
Old Sep 4, 2024 | 07:26 PM
Dave Keefer's Avatar
Car: 1986 iroc Camaro
Transmission: Manual TKX
Axle/Gears: 370
T5 T56 flywheel
Guys, is the manual flywheel for a T-5 and a T-56 different??? Thanks
Old Sep 4, 2024 | 07:55 PM
Firechicken82's Avatar
Car: 82 TA
Transmission: Magnum f
Axle/Gears: Ford 9 w 4.11
Re: T5 T56 flywheel
Yes and no. It depends on the clutch setup. For me- no, I have an 86 and up stock flywheel and a ram 82-92 dual disk and a hydraulic release bearing w my t56. I have a ls magnum f with a quick time bell. Others use different setups.
Old Sep 4, 2024 | 08:04 PM
Re: T5 T56 flywheel
The LT1 T-56 (93-97 F body) flywheel is different from the T-5.
Some others can use a stock T-5 one. Some can't.
Details matter. It's not a blanket yes/no situation.
Old Sep 5, 2024 | 08:40 PM
jmd's Avatar
jmd
Car: `86 SS / `87 SS
Re: T5 T56 flywheel
They look similar but are not the same. The surface of the 93-97 is noticeably taller. This is for the reversed clutch disc hub to clear flywheel bolts.
Though there are some custom, or non-stock parts that can be used together, those are best used by an owner-mechanic with experience. If a shop gets tired of having to think to install something, they will pass the buck onto the owner.
S_Johnson
Jul 6, 2012 09:17 AM
Dante93GTZ
Sep 29, 2010 07:25 PM
BCdawg57
Jan 12, 2008 04:36 PM
snowman89
Jun 30, 2004 01:09 PM
383GTAT5
Mar 20, 2001 10:51 AM
