88 Iroc 9 Bolt Question?
Old Oct 14, 2024 | 12:35 PM
cwb90's Avatar
Can a 9 bolt from a 88 Iroc be rebuilt by just buying a new series 3 posi unit carrier and gears or do they take special parts? I couldn't really find anything from Summit that fits this year. Thanks
Old Oct 14, 2024 | 01:39 PM
Re: 88 Iroc 9 Bolt Question?
Yes it can be "rebuilt".
No the parts aren't "special", any more than any parts for any model of rear axle are. 9-bolts use 9-bolt parts, which, like every model of rear, are different from the equivalent parts in any other axle model though, if that's what you mean.
No I doubt Summit carries many parts for that rear. Usual source for parts for those these days is 9bolt.com which is in Australia. Pretty sure they can hook you up with a carrier. Maybe even a newer, worm-gear style one.
Old Oct 14, 2024 | 02:19 PM
thatsupnow's Avatar
Car: 1991 camaro Z28
Engine: Forged 370" LS turbo s488
Transmission: Built 4L80e FTI converter
Axle/Gears: MWC 9" 35 spline 3.25 gears
Hot damn Australia! It probs be cheaper to just find a 10 bolt on this side of the world and rebuild it wouldn't it??
Old Oct 14, 2024 | 03:39 PM
Most likely.
Old Oct 14, 2024 | 06:51 PM
jmd's Avatar
jmd
Car: `86 SS / `87 SS
The rear and its' successors were used more globally than N. America. Some reading (I would consider this.): https://www.thirdgen.org/forums/tran...rg-warner.html
Old Oct 18, 2024 | 09:13 AM
TransamGTA350's Avatar
Car: '89 GTA
Engine: ZZ6TPI
Yes, the 9-bolt rear can be rebuilt. No, you can't get a new carrier from Summit, Jegs or anywhere else here in the states. All you can get around here are bearings, seals and 3.70:1 Motive ring and pinion gearset. 9-Bolt.com, out of Australia is a good vendor to get the other parts you can't get here. The original posi carrier is rebuildable with new friction cones and spider gears (available from 9-Bolt.com), or there are Torsen carrier options available from Australia. There are also a couple of things you can do to strengthen the 9-bolt (or a 10-bolt for that matter), such as a T/A Performance rear cover and pinion crush sleeve eliminator kit.
Overall cost will be a little higher for the 9-bolt parts compared to a GM 10-bolt, but you already have the 9-bolt. I would not go buy a 10-bolt and then rebuild it, that would negate the cost savings. If you were able to get a free 10-bolt, then it could make more sense.
The 9-bolt is a pretty good piece overall with a 4-pinion carrier, no c-clips to hold the axles in and inner bearing races for the axle bearings (instead of using the axle as the race).
Old Oct 18, 2024 | 09:55 AM
TTOP350's Avatar
Engine: 4++,350 & 305 CIs
There's a torson diff on ebay to replace the factory junk cone diff.
Old Dec 7, 2024 | 05:12 PM
88IrocRRS's Avatar
Car: 1988 Iroc-Z
Engine: 5.7TPI
Axle/Gears: 91z28 10bolt, 3.23
I have an 88 Iroc that had the 9-bolt that I bought in 1999 that I was building a 400sbc to put in it. I had a 2.77 gear and if I remember there were one or 2 choices of gear I could find. The problem for me was that you needed a different carrier for the 3.+ gears that were no place to be found, new or used. I really wanted to keep the 9 bolt but after searching for parts for months, I ended up buying a 91 Z28 10-bolt, which is a step up from the early 3rd generation 10-bolts. If I remember correctly, the gear diameter went from 7.5" 26 spline axles to a 7-5/8" 28 spline axles. This was back in early 2000's, so I don't know if things are different today. I think all of the 10-bolt housings are all the same 82-92, you just would just need to upgrade the 28 spline carrier, 7-5/8" gear and axles. Also I think you can use the 1993-2002 4th gen 10-bolt axles, but they are a little wider (same bolt pattern to the 82-92) and would probably need different offset wheels. Most of this info I just told you I think I got off of this forum back then.
I happen to have the original OEM Posi carrier from the 91 z28 (had ~38k miles on it) that I replaced with a SLP Torsen take-off carrier. I also have a brand set off Superior Evolution heavy duty axles, P/N EV10-4 and a new never use Superior 3.42 gear. All this will be for sale soon in the classifieds. If you wonder why I have this stuff, you can read about my 88 IrocZ that's been sitting for 20 years. https://www.thirdgen.org/forums/hist...ml#post6548882 I also have pictures of this stuff if you were interested in going this route. I just remembered I also an Aluminum heavy duty differential cover I am removing that I am going to sell also.
Old Dec 8, 2024 | 04:47 PM
TylerSteez's Avatar
Car: 86 Trans Am WS6
Engine: 383 stroker
That thread shows how to put a torsen in a 9 bolt housing with part numbers. I just completed this myself with a 3.7 ratio and am looking forward to putting the rear end in the car this spring.
jbates346
Dec 1, 2019 04:25 PM
djtricia
Dec 29, 2005 11:52 AM
vic_V8
Apr 25, 2002 01:23 AM
