Best way to limit axle play in 10 bolt C-clip rear axle?
Old Dec 14, 2024 | 11:41 AM
83RDRACR's Avatar
I have a rebuilt 10 bolt axle with all new bearings, seals, Yukon posi, 3.73 gears. It works very well but I think axle endplay may be causing brake pad knock back, making for excessive brake pedal travel on initial application of the brakes. Second pump is higher and rock solid.
other than running c clip eliminator what are some ways to reduce axle end play?
Pic for attention.
Pic for attention.
Old Dec 14, 2024 | 01:00 PM
Re: Best way to limit axle play in 10 bolt C-clip rear axle?
New C-clips, new axles
Old Dec 14, 2024 | 11:01 PM
Beeman's Avatar
Just a guess but I doubt the axle play is moving the pads. Factory pistons are a pain to move back even when they're new because of the parking brake setup. Try applying the parking brake before stepping on the pedal to see if it's better.
Old Dec 15, 2024 | 10:32 AM
RJ IROC's Avatar
Car: 1985 Camaro IROC-Z
Engine: 383 HSR Comp XFI280HR Profiler 195s
Axle/Gears: 3.73 Posi
I cut some new C clips from a piece of 4140 pre-hard plate, put it on a surface grinder, and ground it thicker than the original c clips. I have less than .005” of axial movement on each side, verified with an indicator. This is the only way that I know of to get less side to side movement. Replacement c clips leave a ton of slop in the system.
Old Dec 15, 2024 | 11:09 AM
Depends on the axles. Stock CRAP, sure; esp if wore out. Others, maybe not.
Which is why I named BOTH of those things.
Keep in mind also, that in a clutch-type posi rear, as the clutches wear, the side gears sink deeper into the carrier, away from the cross pin; which increases axle end play as well. In the case of the OP he states he has a "new" posi so I didn't mention that factor. Could well be though, that his side gears are already too deep, in which case, ... you do the math. Yet another good argument in favor of doing away with Stone Age clutch posi systems and changing to worm gears.
Old Dec 15, 2024 | 02:03 PM
DynoDave43's Avatar
Axle/Gears: 10 Bolt 2.73 Open
I have a pair of Moser axles I'll be using. "Perhaps" they will tighten up an excessive endplay...time will tell.
Aside from the aforementioned custom work by RJ IROC, does anyone make these clips in custom widths?
Old Dec 15, 2024 | 02:38 PM
I don't know of any; butt it wouldn't be too terribly hard to make up something out of shim washers.
Not to be an a$$ or anything, butt it's almost impossible to believe that anybody the least bit serious about any kind of "racing", at least in any class or whatever where it would be allowed, would be running TOTAL CRAP stock axles ANYWAY, especially while sitting on a pair of something better. I think I'd suggest getting out there and changing out that CRAP before posting any more about it on the Interwebz.
Come back and check further if the results aren't sufficient.
87zz28
Sep 26, 2016 09:24 AM
jamon8
Sep 3, 2007 08:05 PM
Tony89GTA
Jul 2, 2004 04:08 AM
87ROCZ
Apr 10, 2003 05:49 PM
urbman
Jul 15, 2002 11:35 AM
