4L60E build
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
4L60E build
Anyone buy parts from Dana at @Pro Built Automatics ? Looking at this kit: https://probuiltautomatics.com/shop/...998-early-2006
Curious if there is anything else that should go into this build that is missing from the kit. I'm going to try and find a 2002ish core, which I believe should have a 5 pinion planetary.
Re: 4L60E build
I bought a kit from him acoupla years ago. Looks very similar to that one there. Put it in a 4L65E out of a 05 or 06 Escalade, for my 04 Avalanche. Added a Yank 2800 RPM converter, which turns out to stall closer to 2950 or 3000.
I'm very happy with it. Worked perfect the first drive if a little bit ... strange. It took awhile for the ECM to adjust itself to it; I guess it gave the ECM a VERY different view of the world than a failing 275k 4L60E. Took a few months of driving before it all settled down. Particularly, around town, it almost always applied the clutch immediately after shifting into 4th, butt as time has gone on, it seems to go into 4th sooner, and the TCC a bit later. Still all well within good street driving manners. Shifts are quick and snappy without slamming or any of that, both up and down.
I highly recommend it. He's a great guy to talk to as well; turned out, we knew a whole bunch of the same people. Regardless, he knows his poop, and I think he'll do you right, even if that exact combo of parts isn't exactly what you need.
Note also, one thing he sent that isn't in that pic although he mentions it in the description, was a rebuild training video on DVD. It was REALLY good, in terms of showing which parts went where, what to look for in used parts as far as wear, the order of assembly, etc. Although not earth-shattering or anything, it was extremely helpful, especially as a reference to go back and look at as I was working.
Look for transmission codes ending in KZD to get the 5-gear planet aka 4L65E. Not sure what the earliest years for that are, butt I'm pretty sure they were available at least around at least 04 - 06. I think 07 up has an additional speed sensor for the input shaft, and maybe some other electronic differences, but no doubt Dana can fill you in on all that.
Car: 1988 camaro z28,1997 camaro lt1
Engine: 355 afr 195 heads,tpis big mouth
Transmission: 700r-4 built by me 3-4 z pack
Re: 4L60E build
5 pinion is not really stronger than a four pinion planet
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
Re: 4L60E build
My buddy recommended a 2800 stall circle d converter, but I feel like that is an absurdly high stall given the cam I'm running (209/217) on an LS with a reported RPM range of 1800-6200. (https://www.summitracing.com/parts/SUM-8719-1) They don't even recommend increasing the converter stall from stock (which is likely 1700 I think).
Re: 4L60E build
My engine is a stock LM7 w headers and better valve springs, and nothing else. Including the stock cam still in it. The converter made a MASSIVE difference to the truck's launch and low-speed performance. My stock converter stalled at around 1800 or so it seemed. Personally I think you'd benefit more from a higher stall converter than you would from changing the transmission gearing butt it's hard to say for sure. Summit's "recommendation" is aimed at people who want a cam but don't want one that "requires" a higher stall, which of course is VERY DIFFERENT from "would benefit from".
Re: 4L60E build
Stick with 4 pinion planets. They are made of better material and wear better. The 2.84 gearset is a waste of money and you will not see any gain in the quarter mile.
The 1-2 at a 6,000rpm WOT shift will show 168rpm difference closer with the 2.84 - 1.57 gear set, instead of 3.06 - 1.63. The 2-3 at a 6,000rpm WOT shift will show a 141rpm difference closer with the 1.57 - 1.00 gear set, instead of 1.63 - 1.00. Remember this is not taking in torque converter slip and transmission shift times. This would account why I have never heard of anyone reporting a gain using the 2.84 gear set since they came out. Spend the approximate $600.00 on the right diameter and stall torque converter will do more than anything else for seeing gains here.
Even completely stock motors will always see a gain with the right torque converter in the quarter mile.
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
Re: 4L60E build
The sonnax gear set is actually $859 now, plus $217 if you use their HD reaction shaft.. So yeah, it's expensive!
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
Re: 4L60E build
Figured I'd update this.
I bought the street elite kit from Dana and rebuilt my 4l60e over the winter, along with an edge torque converter.
I had to swap out a couple of steels to shim things within spec.
I used the sonnax vac tool to test my VB and ensure no cross leaks.
Have road tested the car several times. 12psi boost WOT blasts, normal driving, up down hills. So far so good!
I'm using an aftermarket TCU and I'm happy overall with the transmission programming. So far the hottest I've seen the trans get is 180 degrees on a 85 degree day. I'm using a single standalone cooler and a fan.
Right now I'm only locking up in 4th gear above 43mph. Unfortunately, that also means I'm hardly ever locking up since most back roads are 40mph or less. I need to rethink that I suppose.
Currently I'm shifting into 4th between 0-20% throttle at 42mph, so most cruising is with the converter unlocked. it won't downshift into 3rd until speed drops below 24mph.
With my 3.89 rear end and 26.65" tire, that puts me at a 1373 RPM cruise at 40mph,
Re: 4L60E build
There is no surprise that a "Pro Built Auto" spec'd Transmission is doing well...
Dana put a ton of time into curating those "Kits"!
He would contact Engineers from GM and Aftermarket Parts Companies to really get things figured out, and He did a great job!
My father was one of the Engineers that he would collaborate with.
