Stupid converter ????
Old Jan 25, 2002 | 01:48 PM
shiner16's Avatar
Alright, this may sound silly, but aren't torque converters supposed to be sealed? I set the converter from my TH350 down on my garage floor and noticed what looks and stinks like ATF on the floor later. When I turn the converter over, I can see fluid inside the hole where the tranny input shaft fits. Is this just ATF that leaked in there when I yanked the tranny or what?
Old Jan 25, 2002 | 08:16 PM
Jay 727's Avatar
Re: Stupid converter ????
Originally posted by shiner16
A. When I turn the converter over, I can see fluid inside the hole where the tranny input shaft fits.
Sounds like you set in on the ground with the drive tube down, you could have leaked out about a quart and a half at least. Fluid runs through the converter, it makes it work actually, so yes it's normal. In fact if you install a new converter it should get filled with at least a quart before installation. I usually set converters on a bucket with the pump drive down, it'll drain most of the fluid out.
Old Jan 26, 2002 | 01:28 PM
shiner16's Avatar
thanks much for the clarification, I know next to nothing about torque converters. So, I should just drain it and fill it w/ about a quart of ATF before installation?
FormulasOnly
Jul 23, 2018 08:47 AM
okfoz
Oct 13, 2015 02:19 PM
bjpotter
Oct 2, 2015 09:12 AM
timbuck
Convertibles
Sep 28, 2015 12:31 PM
indygene
Sep 26, 2015 11:21 AM
