4L60 TCC info
Old Mar 1, 2026 | 12:45 PM
mjgord51's Avatar
Car: 14 & 96 Camry's, 68 C10,70 Z28
Engine: Depends what vehical I'm driving
Transmission: Also depends which vehical
Axle/Gears: Also depends on vehical
4L60 TCC info
I have a much neglected project with a 1992 - 4L60 (non E) that won't be using a ECM to activate the TCC 4th gear loc-up.
Since I won't be using a ECM and will be needing some assortment of parts (OEM & some aftermarket) is there a simple way or complicated way that replaces the ECM's signal to lockup in 4th gear only? A tried and true methiod would be GREAT as ive seen and read multiple ways to do it (Professional and Backyard ways), some with few parts and then some with more parts as well with much more $ dollars involved. ANY help or Links is Greatly Appreciated !
PS; The Vehicle is a 68 C10 with a SBC motor. Trans casting #'s 8676358, Suffix code 2FTM098H passenger side above pan location.
Both motor and trans are from Firebirds, 1988 305 motor and a 1992 4L60 trans - this is why I've posted here thinking I would get the best help.
gregsz-28
May 26, 2009 01:07 PM
rgarcia63
Dec 28, 2008 12:05 AM
Nitsuj86Iroc
Jun 20, 2007 06:55 PM
Stevie
May 30, 2003 09:21 PM
flotsamm
Oct 8, 2002 01:08 PM
