Disconnecting the ECM, effect on auto trans.
Car: 85 Camaro
Engine: No
Transmission: No
Axle/Gears: No
By disconnecting the ECM and driving my car, will I damage my 700r4?
Also, I thought only one wire was required to operate a lock-up converter, but it seems that multiple wires go to the transmission, so, if I am right that there is more than one wire going to the transmission, (I didn't investigate much, or even go under the car and look), what do they all do?
Car: check
Engine: check
Transmission: check
Re: Disconnecting the ECM, effect on auto trans.
The only thing the ECM controls in the 700R4 is the TCC lockup. The other wires are for power to the TCC solenoid and the 4th gear switch back to the ECM.
Note that when the TCC is unlocked that the flow of ATF through the cooler is greatly reduced. On the early 700R4's the flow is actually stopped when the TCC is unlocked.
Best bet is to use one of the aftermarket TCC control setups for the lockup.
RBob.
RBob.
Car: 85 Camaro
Engine: No
Transmission: No
Axle/Gears: No
Well that's a result I never would have guessed. With all the wires for the TCC lockup, can I make a manual switch for the converter? I don't plan on having this transmission for more than a few more months, so I'd prefer to not have to buy an aftermarket control setup for the lockup.
What's the '4th gear switch back to the ECM.'? What do I affect by disconnecting that?
Thanks for the answer, I thought I would have to 'bump' this thread a couple times...
Car: 86 Firebird
Engine: 305 SBC
Transmission: 700 R4 TCI
I can answer some of that. The 4th gear is overdrive and the ECM shifts the car into it and out of it based on gear shift position and throtle position and the TV cable position etc. It is a nuisance really. Flat out on my GTA I get an overide on the overdrive which puts me back into third gear or I can back off the gas a little and go the same speed in overdrive annoys the heck out of me.
Car: 85 Camaro
Engine: No
Transmission: No
Axle/Gears: No
.All 700r4's kick you out of overdrive past 1/3 throttle.
But, do you mean that mine won't do that with the ECM disconnected?
I drove my car just around the neighborhood real quick right after I disconnected the ECM to make sure all systems on the car still worked correctly, and it still shifts in to overdrive just fine, except my converter obviously doesn't lock up anymore.
So, in addition to my questions in post #3, how many wires go in to my transmission? And, can I make switches to manually control their operation?
Car: check
Engine: check
Transmission: check
The 700R4 won't lock up the TCC in 1st, nature of the beast. It is only capable of locking up in 2nd, 3rd, and 4th.
The 4th gear switch tells the ECM whether the trans is in 4th or one of the lower gears. This is the true gear, not the shift location. The ECM then adjusts the TCC lockup points accordingly. If you remove the ECM then the 4th gear switch doesn't matter.
Except that it can sometimes be used for auto-lockup once the trans reaches OD.
RBob.
Car: 85 Camaro
Engine: No
Transmission: No
Axle/Gears: No
Car: check
Engine: check
Transmission: check
The TCC pin on the ALDL connector gets grounded to lock up the TCC. Just need to put a switch between that wire/pin and ground. Turning the switch on grounds the TCC solenoid activating it.
RBob.
Car: 85 Camaro
Engine: No
Transmission: No
Axle/Gears: No
I didn't think the ALDL connector would work with the ECM disconnected? I didn't look at the wiring that much though, but am I right?
Car: check
Engine: check
Transmission: check
The ALDL connector pin for the TCC goes to both the ECM and the trans. Put another way, the ALDL pin doesn't tell the ECM to lockup the TCC. The TCC pin on the ALDL is the same wire that goes to the trans.
With or without the ECM tying that pin to ground will lock the TCC.
RBob.
RBob.
Hang on a second.
I just unplugged the TCC from the transmission this evening after having removed the ECM. The ALDL would obviously have to run through the ECM and THEN to the transmission.
Let's put it this way.
I've stripped out all of the wiring and the ECM from the vehicle. How do I wire up the TCC lockup switch now?
Car: 85 Camaro
Engine: No
Transmission: No
Axle/Gears: No
Hang on a second.
Those are the words I was trying to say!I haven't tried to make my lockup switch yet, I haven't been driving very much anyways, been VERY busy lately.
I've been using a diagram off of Autozone for removing the ECM. What I've noticed is that there exist a pair of plugs that feed somewhere to the drivers side of the vehicle. I sense that one of these is for the ALDL. Therefore, there is a continuation as the wires would go into the ECM and back out into the engine bay. From there it would extend to the transmission.
What I'm thinking of doing is wiring through the firewall on the drivers side from a button on the center console down to the transmission. My only issue then is, does the button need to connect to some sort of power source? I don't do much wiring so I have a hard time understanding how the lockup is "activated". What wire can I tap into (radio, ignition, ECM seeing as how it still has a fuse but is not really powering anything)? If it doesn't need a power source, there's actually a hole in my floorpan from the past owner that I could just drop the wire down through.
Car: check
Engine: check
Transmission: check
Well, yes, if you remove all of the wiring then additional work will need to be done. But this isn't "disconnecting the ECM."
Grab the 4-pin connector that plugs into the transmission. Pins A & D are the two you want. The letters will be molded into the housing.
Pin A gets IGN+ power via the switch on the brake pedal. Pin D gets grounded to activate the lockup.
RBob.
RBob.
Car: 1987 Trans Am GTA
Engine: 355
Transmission: TH-700r4
So are you saying that the ECM grounds the tcc, which activates it, but you can ground it manually via the ALDL?
Also, is there a way to make the aftermarket lockup harness at home so we don't have to spend a lot of money on some wires?
Car: check
Engine: check
Transmission: check
https://www.thirdgen.org/forums/tran...-kickdown.html
https://www.thirdgen.org/forums/tran...up-tourqe.html
RBob.
Hotrodboba400
Dec 10, 2019 07:07 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
