replacing posi/gears
Old Jan 27, 2002 | 06:16 PM
86Z's Avatar
86Z
Car: 1986 Camaro SC
Engine: 305 TPI Procharged D1SC
Transmission: Tremec TKO-600
Axle/Gears: Moser 12 Bolt 3.73 posi
hey guys i have a new posi/gears i wanna put in my car, i have a posi with 3.23's in their now, i'm gonna be replacing the axles also, my qustion is do you need a dial gauge to install it or just get the gear pattern right?
Old Jan 27, 2002 | 06:28 PM
Jay 727's Avatar
You should have a dial indicator to do it right. Some swear you need a pinion depth checker also, these people don't realize that not all pinion gears come with a checking depth stamped on them. If your gears don't have the pinion depth stamped to them your only way to install them is by tooth contact pattern. You also cannot get the correct contact pattern without the backlash being set right, so in my opinion a dial indicator is not always necessary either. Check http://www.ring-pinion.com.
Out-Cast
Dec 31, 2015 04:40 PM
Dan Hubbard
Aug 12, 2015 09:05 PM
marcusaw
Aug 10, 2015 08:13 AM
Fronzizzle
Aug 9, 2015 01:15 PM
