1/4 mile gearing
Old Jan 28, 2002 | 12:14 PM
89formula4life's Avatar
1/4 mile gearing
Ok, i know everyone has heard this lots before but, i figure this is the place to go to get good answers about my set up...
I have what is in the signature and I was planning on getting
3. 73 gears but a lot of people are telling me that putting that small of gear in is over doing it for my engine...is this true?? so what is a good size for my car??I am thinking 3.4x....and i want a gear that will be good for my mods now and good if I ever put a 350 in my car.. anyway thanks in advance Corey
Old Jan 28, 2002 | 01:42 PM
Mark A Shields's Avatar
Car: 99 Formula
Axle/Gears: 342
If you don't plan on changing cams then yes 3:73s is a little overkill. You'll get better performance from 3:42s. I'm sure you 0-60 time will be faster w/3:73s but 3:42s will get you better 1/4. I went with 3:73s and with a cat-back dropped only 1/10. Come to find out the cam in my motor stops making power past 3500 rpms, so the gears are keeping me out of my power band. Now it's time for a cam swap.
Old Jan 28, 2002 | 01:55 PM
btw
my tire size is R16
Old Jan 28, 2002 | 03:07 PM
Car: 99 Formula
Axle/Gears: 342
Your tire height is more of an issue. With a taller tire the ratio will numerically be lower.
Old Jan 28, 2002 | 05:41 PM
So if I have 16" tires/rims what do you think the best gears would be for my car?
Old Jan 28, 2002 | 06:54 PM
Car: 99 Formula
Axle/Gears: 342
You're tires will be taller than 16" tires. Right now I have 25" tires on the back of mine. Just go out and take a measuring tape from the ground to the top of the tire, that's what I did.
Old Jan 28, 2002 | 09:11 PM
Brrrrrrrrrrrr...... its cold out it is 11 pm here and i just went out and dug my car out of 3 feet of snow and had half the car cover off for this... on the tire it says 245/50 R16.... now you guys have to help me cause i am half froze to death..
Old Jan 28, 2002 | 09:29 PM
N E 1
Old Jan 28, 2002 | 11:19 PM
RedFirebird's Avatar
Car: 1988 Trans Am GTA
Engine: 5.7L TPI (L98)
Transmission: 700RJunk
With 245/50/r16's you will have 25.6 inch total tire height.
hope that helps
Old Jan 29, 2002 | 09:06 AM
ok with that know to all can i get some fellow F-body owners to help me out... i wouldn't be puching so hard on this but i am going to look for gears tommorrow.... and can someone tell me everything i will need to know before, I have the factory 2. 73 10 bolt rear right now... thanks guys keep the replys commin..
Old Jan 29, 2002 | 10:34 AM
...... I need this
Old Jan 29, 2002 | 02:47 PM
Pro Built Automatics's Avatar
If you do a little research on this you will find that the 9.5" Vigilante or A.C.T. will give you an increase in performance better than a rear end gear change. I have seen .5 second drops in ET with TC changes, and somewhat less for rear end gear ratio changes. Prove it to yourself as to which way to go before spending the money.
Old Jan 29, 2002 | 03:19 PM
u r sofa king we tah did's Avatar
hes right. i dont know what intake you are running, but if you have a stock TPI setup 2.73 or 2.77 is actually the best gear for 1/4 mile et and mph. not so great for the street though. get a good quality 9 inch 2600-2800 stall, then do gears later.
Old Jan 29, 2002 | 03:38 PM
I have whats in my signature the motor is stock what would be the best TC
Old Jan 29, 2002 | 04:24 PM
tbi...
get a good converter like vigilante (id recommend 2600-2800). vigilante converters are very streetable so you probably wont even notice it until you smash on the gas. then since you have an auto, go with some 3.42 rear gears after the converter.
italiano67
Dec 11, 2016 09:21 AM
Reddeath210
Oct 6, 2015 08:20 AM
Camarothatcould
Aug 20, 2015 08:49 AM
jbd1969
Aug 17, 2015 07:06 PM
