9-bolt discs to a 10-bolt
I have a 1989 IROC-Z with a 9-bolt borg and warner on it. I was planning on building up a 10-bolt for it. But what i want to know is if the rear discs from the 9-bolt will bolt directly to the 10-bolt.
thankx
thankx
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
As long as the 10 bolt is an 89+ disc rear, or else you'll have to change the backing plates.
Car: 2015 Camaro Z/28 & 2013 Super Bee
Engine: LS7 and 392 HEMI
We did that w/ my 89 IROC. It involves drilling new holes for the caliper mount bolts on the ends of the 10-bolt housing that is to be put in. After this, you will then need to space out the caliper mounts as needed so the discs fit in the caliper properly. For more in depth instructions, email TPI Guy, he did most of the work on it.
Engine: 383 Carb
Transmission: 4L60
If it's a disc rear, you'll have to drill as mentioned. If it's a disc rear, you should be able to just pull the axles, unbolt the backing plates, and bolt the new ones on.
Don't forget that you'll have to re-shim your caliper carriers in any case.
KO1
16
Oct 15, 2015 05:00 PM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
