9 bolt posi question
Old Feb 10, 2002 | 07:16 PM
kream-'s Avatar
I'm running a 9 bolt 2.77 rear with 55k miles on it.
If I buy a different used complete rear can I put my posi in it or does the posi basically = the carrier?
Old Feb 11, 2002 | 06:45 AM
irocnroll89's Avatar
From: previously OKINAWA JAPAN,georgia, now new england
Car: 1989 IROC--1989 T/A
Engine: 5.7 TPI in both
Transmission: W/C T-5 in both
Axle/Gears: B/W 3.27 in both
i believe "posi" and "carrier" are on and the same. In short i would just yank the carrier/posi out bolt on the ring gear and go. This is assuming you have problem with your 2.77, and have no intention of going to a bigger gear.
Old Feb 12, 2002 | 06:46 PM
88 427 Camaro's Avatar
Car: 88 Camaro
Engine: 427 BBC
Transmission: T400
Carrier is what the ring gear bolts to. The posi is what's inside of the carrier. In general terms they are the same thing. All 9 bolt 2.77's are series 2 posi carriers. 3.27+ are series 3.
PS If you took out the posi/carrier, what would the ring gear bolt too unless you had a full spool.
Miles
hectre13
Dec 11, 2023 08:14 AM
hectre13
Aug 26, 2015 08:17 AM
redmaroz
Aug 16, 2015 11:40 PM
1992 Trans Am
Aug 8, 2015 08:16 PM
