HELP! 305 flywheel won't fit 70's 350 crankshaft..70's 350 flywheel will not fit too?
Old Feb 10, 2002 | 08:44 PM
smoke the tires's Avatar
Hi All-
I was ready to mate the t-5 tranny and my 70's 350 4 bolt main truck motor on my 1986 camaro z-28 (originally w/ a 305), but when I tried to put the 305 flywheel on the crankshaft, it would not slide on the crankshaft and the bolt holes didn't match anyways..So I got my hands on a 70's truck flywheel and it fit but when I tried to put the 86 bellhousing on, it would not fit over the flywheel? What should i do? What is the answer? What flywheel do I need to make this work? Can it be done?
I have searched old posts but nothing...please give me a couple answers...thanks so much..
Dan
Old Feb 10, 2002 | 08:50 PM
87RS402's Avatar
I've been through this before so here ya go.
What you need to a 153 tooth flywheel for a 2pc rear main. The best source is a junkyard, ask for a flywheel for a 82-85 Camaro/Firebird. You can not use a 168 tooth, it has to be a 153 for a 2 pc rear main seal and you have to use the stock 305 starter.
If you don't want to do that you can get a lakewood scattersheild and use the 168 tooth flywheel and a larger clutch with the correct starter.
Old Feb 10, 2002 | 09:37 PM
Hey 87RS402
Thanks a lot, thats exactly what i needed to know...I appreciate it a lot...thanks
Dan
Jake_92RS
Jan 28, 2020 10:37 PM
BlackphantomZ28
LSX and LTX Parts
Oct 19, 2015 06:25 PM
justin57
Aug 20, 2015 07:05 PM
st.evel07
Aug 13, 2015 06:15 PM
BBSDesigns
Aug 11, 2015 07:39 PM
