anyone running larger volume tranny oil pan?
Old 02-18-2002, 08:27 PM
farm-kid/88camaro's Avatar
I've got a aftermarket aluminum tranny pan which allows a couple extra quarts of fluid and has cooling fins on the bottom.
Does anyone run one of these pans on their tranny? I had it on for a while put it seems like it hung down way to low.
I'd like to have it on but dont really feel like having it catch on something, on the other hand the extra capacity and cooling effects would be nice.
Whats everyone's experience with these?
Its a 700R4 by the way
thanks
Old 02-19-2002, 03:17 AM
Pro Built Automatics's Avatar
You might have some benefit of a temperature drop, but the decreased clearence can raise the possibilty of the pan breaking (from striking something) and losing all its fluid. If you want a deeper pan, make sure it is a steel pan and not a cast aluminum. From my experience, the stock pan works out fine! I have used it in all my performance rebuilds.
Old 02-19-2002, 05:16 PM
ryn28's Avatar
Car: 1986 Camaro Z-28
Engine: Chevy ZZ4
Transmission: Select Built 700R4
Axle/Gears: Moser Axles / 3.73 Richmond Gears
I'm using a TCI one. It's aluminum with the drain plug which makes doing a fluid/filter change that much easier. The car's not my daily driver but as long as you're aware of it you should be OK.
The only problem I see is that for an everyday driver it could be too easy to forget about the lower pan. Going through your daily routine you may not remember until it's too late.
Old 02-19-2002, 09:39 PM
ya, its not a daily driver, so its not a big deal
just wondering if they were all that great, it came with my tranny
thanks guys
Navy8125
08-21-2015 09:32 AM
MY87LT
08-17-2015 08:43 AM
matthew911
08-12-2015 09:38 AM
89mulletbird
Southern California Area
08-10-2015 10:16 AM
gwade12
08-08-2015 08:17 AM
Quick Reply: anyone running larger volume tranny oil pan?
