I've never had this problem before....you?
Old Feb 19, 2002 | 02:07 AM
MATEOZ28's Avatar
ok.......
Brand new probuilt 700r-4 1991 Z28.
Shifts hard. But I feel it changing its mind from gear to gear during normal acceleration (no biggie but not good). Here is the strang thing. When push the pedal down around 95% it launches fine and hard, when I press down further it just lets go and REVS to high heaven without moving. Could this be the TV cable?
Also I installed the B&M megashifter and have not hooked up the relay so the computer can control the lockup. I dont think that has anything to do with it but what can that cause?
Also how long after buying a new trans should I change the fluids in it again? Its been around 2500 miles.
Thanks guy's & gal's.
Old Feb 19, 2002 | 12:35 PM
u r sofa king we tah did's Avatar
my corvette's 700R4 would free rev like that if you floored it before it went out. id ask dana at probuilt, he will help you.
Old Feb 19, 2002 | 04:55 PM
MATEOZ28's Avatar
Anybody else?
This is a probuilt trans
I checked the fluid and it was a little low (1/2 quart)
But what else could be the problem?
I dont want to go out and try it again until I know its safe or not.
Old Feb 19, 2002 | 05:52 PM
88TPI406GTA's Avatar
Car: 2009 Pontiac G8 GXP
Engine: LS3
Transmission: 6L80E
I would definitely call or email Dana and ask him...you don't want to do anything which would void your warranty.
It shouldn't do that...could need a TV cable adjustment or an issue of the shifter not fully engaging a particular gear, if the detent alignment is off just a bit...
Again, call Dana and ask. He knows what he is talking about.
Old Feb 19, 2002 | 05:55 PM
Engine: LS3
Transmission: 6L80E
Also, please let me know, as i just bought a Pro-built 700R4 today...along with a 2600 stall ACT converter. I have faith in the product and finally built up the funds to buy one.
Actually, post the answer for the list...I haven't found anyone yet with a Pro-built tranny that had it fail, at least on this list. It would be good to know the track record that Pro-built has built up....to date, It is 100%, that I have been able to research.
Also, the customer service is one reason why Dana does so well, on top of providing a great trans for the $$$.
Can you tell I am convinced?
pjsparts
Oct 29, 2025 06:39 PM
88rscamar0
Sep 23, 2015 09:08 PM
Ranbo108
Sep 9, 2015 12:20 PM
383cam
Sep 9, 2015 06:01 AM
andy74
Sep 3, 2015 08:41 AM
