S10 Gears and stock limited slip?
Car: 1992 Camaro RS
Engine: 406 SB
Transmission: TH350
I've got the stock limited slip and 2.73 gears and the differential is still good. If I get the 3.73 gears out of an 86-89 S10 Blazer would I be able to reuse my differential?
Andrew
Andrew
Car: 1986 Camaro SC
Engine: 305 TPI Procharged D1SC
Transmission: Tremec TKO-600
Axle/Gears: Moser 12 Bolt 3.73 posi
well you can reuse it but your posi is a 2 series carrier, the 3.73's are a 3 series gear, they make a ring gear spacer to use a 3 series gear on a 2 series posi.
Car: 4
Engine: 6
Transmission: 5
ambainb
Apr 25, 2016 09:21 PM
hectre13
Aug 26, 2015 08:17 AM
now i just have to find the blazer to take it out of.
