Stall converter options
Old Feb 21, 2002 | 08:09 PM
Joshua Leslie's Avatar
Hey all
in a couple weeks im gonna put in a stall converter. I need some imput.
the cam thats in thee now is a no name 262, its got 204&214@.050, has .422&.444 lift.
the cam that is slated to go in there is gonna be a comp cams X/E 268.
the car has 2.73 gears. With stock heads that im going to do some at home porting on.
I was thinking a stall of around 2000, but suggestions would be appreciated. Keep in mind that it is a daily driver.
I am not going to change the gears. I love going 80mph and only 1900RPM or so. Also I get 23 MPG on the highway, and I love that to.
the tranny is a 700r4.
Peace
Joshua
Old Feb 21, 2002 | 10:17 PM
V8Astro Captain's Avatar
Car: Bee-Bowdy
Engine: blowd tree-fity
Transmission: sebin hunnerd
Axle/Gears: fo-tins
Keep in mind that those gears are going to make it stall higher. Personally I wouldn't cam anything with 2.73's.
You can try it and see how it goes
Old Feb 21, 2002 | 10:25 PM
I would consider puttng gears in it, about as high as a 3.23, but I have no idea on how to do it.
I dont feel like paying someone 1000 dollars to do it.
Old Feb 22, 2002 | 02:22 AM
Jza's Avatar
Jza
What's a "stall converter"? Oh, you mean a "higher stall torque converter"...
The easy way out for someone in your situation is to buy a rear end that already has the gears/posi/brakes that you want in it and swap the rear ends. Not everybody can do a gear swap, but anybody can do a rear end swap.
Now, that and what you said about your highway cruising, I'd go with around a 1700 (or close to that) RPM converter. If you're doing a lot of cruising just under the TCs stall speed, you're gonna kill things quickly.
Old Feb 22, 2002 | 08:11 PM
cp87GTA's Avatar
Car: T/A / Grand Am
Engine: 383 SBC
Transmission: glide
Axle/Gears: 9" ford 5.67
Re: Stall converter options
Originally posted by Joshua Leslie
Hey all
Peace
Joshua
The xe268 doesn't start making any power till 1800 rpm. Better call Comp Cams and get their recomendation on rear gears and converter. I'm running that cam in my tpi, 2100 stall, 373 geared GTA. It works real nice, but if you don't want to go to a lower gear you may have trouble, and your lowend power WILL suffer. Remember well selected parts make your car fast, don't match um up and you'll have a dog.
Old Feb 22, 2002 | 08:30 PM
Jay 727's Avatar
I think just about everyone knows what is meant by a stall converter.
Let it go.
Old Feb 23, 2002 | 03:46 AM
Pro Built Automatics's Avatar
First, the 204 - 214 degree cam will give excellent low end drivability. Second, the torque converter will do more than a rear end gear ratio change. (do some research on this to verify it for yourself). Third, a 2,500 rpm stall 9.5" A.C.T. or Vigilante can give you a .3 - .6 tenths drop in the quarter mile. You will not see that with a 3.73 gear change only. Fourth, you will retain the lockup for the same good gas mileage. This TC has good torque multiplication, and will not feel slippery like a reworked (hi-stall) stock 12" TC. These TC's come with a one year warranty and a free stall change if needed. If I can be of help, let me know?
Nervous2
LSX and LTX Parts
Mar 10, 2016 09:49 PM
masonta
Sep 1, 2015 06:40 PM
C409
Sep 1, 2015 03:42 PM
suzuki949
Aug 28, 2015 08:07 AM
Jake_92RS
Aug 17, 2015 09:42 AM
