how much to/you pay for gear install?
Old Mar 12, 2002 | 06:51 PM
t-rally's Avatar
Im going to get some precision 3.73 gears installed with the slp take-off posi. At the place i went to today they quoted me 275 for installation. Is that reasonable? How much did you pay for yours and where did you go?
btw. what do you think of precision gears, the lady says there a lot less whinier than richmonds?
Old Mar 12, 2002 | 08:30 PM
cp87GTA's Avatar
Car: T/A / Grand Am
Engine: 383 SBC
Transmission: glide
Axle/Gears: 9" ford 5.67
Re: how much to/you pay for gear install?
I've never heard of precision gears, but I'm looking at something besides richmond myself. I had richmond 373s in my car and it wined alot. I haven't had a chance to realy check to see if they were installed right yet. They aren't too far off though. I just pulled they complete rearend sat. Worn out auburn posi. It was clanking so bad I thought I broke something. Changing to 28 spline moser axles, eaton posi this time. I hope somebody that know what kind of gears besides oem, runs quiet.
Old Mar 12, 2002 | 11:02 PM
t-rally's Avatar
so you didnt have to pay for your intstall. for me though it'd be better to take it to a pro rather than tingle around with it. i just hope i can find a place that can do it for less than 275!!.
btw the lady showed me a sheet with the gear ratio, tire diameter, and rpm's at 60mph and the 3.73's were around 2650 on 26" tires!!!gas mileage down the drain!!
Old Mar 12, 2002 | 11:38 PM
cp87GTA's Avatar
Car: T/A / Grand Am
Engine: 383 SBC
Transmission: glide
No pay on the install. I do my own. What trans are you running?
I have a 700r4 and turn 2200 2300 at 70 with 245/50/16 tires. That's not to bad. I don't do much state driving though.
Old Mar 13, 2002 | 08:16 AM
82camaro's Avatar
Car: 82 camaro SC
26 inch tires with 3.73's will be 2900 without overdrive.
26 inch tires with 3.73's will be 2050 with overdrive.
If you have a 700r4 tranny.
http://www.f-body.org/gears/
The 3.73 richmonds I have are quiet, but alot of people to complain about them. They are probably the strongest though.
Old Mar 13, 2002 | 10:20 AM
Ringmaster72's Avatar
Car: 1989 IROC
$275 is way too much for install. I had a new posi unit, gears and all bearings and seals done for $100 labor. I know that is cheap, but it is a guy working privately. I did, however, have two other quotes of $120 and $150.
Tim
Old Mar 13, 2002 | 11:38 AM
t-rally's Avatar
i have the 700-r4 tranny. im going to shop around to find a better deal on the install. i got to wait for my posi's to come in anyway.
Old Mar 13, 2002 | 02:20 PM
Mark A Shields's Avatar
Car: 99 Formula
Axle/Gears: 342
Mine are quiet too, I think it all depends on how they were installed, if done correctly they won't make noise. I got a good deal for $150 on the install. Came out perfect. Also I went from 2:73s to 3:73s and didn't lose any mpg, I turn 2500 rpm @70.
Old Mar 13, 2002 | 04:10 PM
heavy_chevy29's Avatar
Car: 84 camaro Z28
Engine: 434sbc
Transmission: powerglide
Axle/Gears: moser 9" with 411 posi
do it your self. its way cheeper
Old Mar 13, 2002 | 07:32 PM
u r sofa king we tah did's Avatar
if you havent done it before, id get it done professionally. otherwise those gears you just bought will last about 10 minutes and be in a million pieces. around 225-250 would be normal rates for a posi-gear set up.
hectre13
Dec 11, 2023 08:14 AM
IROCZDAVE (88-L98)
Oct 6, 2016 09:08 AM
hectre13
Aug 26, 2015 08:17 AM
kyleb24
Aug 15, 2015 08:24 AM
dhonda200
Aug 11, 2015 11:50 PM
