Shifts good in drive, but won't manual shift into third at all
I put 3.70 gears and a tach with shift light in my car over the weekend and now I can't get it to shift into third now. I can leave it in drive and it shifts great , but I need to manually shift it at the track because I loose 1000 rpm from my power band leaving it in drive. When I manually shift into second it shifts, but when I shift in third the shifter shifts to third, but the transmission doesn't. What could cause this to happen?
I wouldn't think a gear swap or adding a new tach would have any effect on how it shifts. I am running the 700R4 which is supposed to be beefed up quite a bit, but I am having my doubts now
I don't think he put a shift kit in either because my shifts aren't firm and it doesn't shift as soon as I shift when I am racing. Any help would be great.
Car: 1988 Firebird S/E
Engine: 406Ci Vortec SBC
Check the fluid level.
Mine was doing the same thing and after slightly
overfilling the fluid level (1/2 QT) it seems a lot better.
It was origionaly, just underfilled by about 1/2 Qt low.
An intermiddently sticking valve in the valve body can cause this
too.
The fluid level is the first place to start looking in any case.
too.
1992 Trans Am
May 10, 2023 07:19 PM
dhonda200
Aug 11, 2015 11:50 PM
