Problems removing driveshaft!?
Old Mar 14, 2002 | 01:06 PM
427camaro's Avatar
Car: 05 Nissan Xterra
Engine: 4.0L DOHC
Transmission: 5 Speed Auto w/ OD
I've removed the 4 bolts from the rear of the driveshaft, it won't come out. I don't want to knock it out of balance by banging it with a hammer. Any suggestions??
Old Mar 14, 2002 | 02:20 PM
1991tealRSt-topGuy's Avatar
Car: 1991 Corvette Coupe
Transmission: 700R4/4L60 same trans different name
ummmm i assuming you removed the 4 bolts, THEN slid the slip joint end into the tranny's tailshaft.......that should give you the clearance you need.........
Old Mar 14, 2002 | 03:12 PM
SIMON HOLTBY's Avatar
I removed mine the other day. After removing the 4 bolts and bearing holders I could not remove the shaft from the rear diff by hand. Problem is that the bearings rust onto the diff part of the UJ. I shoved a big screwdriver in there and levered it off. Mind one of the snap rings/circlips broke but I think this was because it was so badly corroded. Be carefull those bearing caps dont fall off as the needle bearings will fly everywhere. Also mark the shaft so you put it back in the same position and treat the shaft carefully not knocking any balance weights off.
Simon.
Old Mar 14, 2002 | 04:50 PM
427camaro's Avatar
Engine: 4.0L DOHC
Thanks Simon, your advise helped me alot. All I needed to do was pry it apart!
Old Mar 14, 2002 | 09:11 PM
92blue's Avatar
Former Sponsor
Car: 1992 Camaro RS
Engine: Yet another 350 TPI
Transmission: Borg Warner 6 spd
Since I've had my car (2yrs), its had marks on the driveshaft as if weights were once on there. The problem is, they aren't on there now. How significant is this? I would imagine this would cause a vibration, but the only thing I've noticed is a whine from about 40-50 in drive, but I think thats the rear end.
Old Mar 15, 2002 | 10:51 AM
If the prop is out of balance it wont be a whine you hear but a rumble/vibration at a certain speed. If you dont experience any problems I'd forget about it. Just give the axle an oil change.
Simon
theurge
Aug 21, 2015 12:46 PM
overdriv
Aug 20, 2015 03:52 PM
gta power
Aug 13, 2015 06:15 AM
3rdgenparts
Aug 8, 2015 07:09 PM
