12 Bolt
Old Mar 14, 2002 | 11:49 PM
PimpCamaroRS's Avatar
12 Bolt
looking for a cheap 12 bolt or 9'' for CHEAP. i just need some thing t keep up wth mysuper charger and i know my 10 bolt will snap like a twig.
Old Mar 15, 2002 | 07:11 AM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
All the aftermarket bolt-in 12 bolt or 9" diffs for third gens are around $2000 for a complete diff.
Old Mar 15, 2002 | 11:58 AM
ya i know, i just was wondering if any one new the CHEAPEST one. or is tere an other way to get my rear to take 500 horses
Old Mar 15, 2002 | 08:33 PM
AlkyIROC's Avatar
Car: 87 IROC L98
My old 10 bolt took 500 HP. It was beefed up as per the "ultilate 10 bolt buildup". The only reason I went with a 9" is that I've gone with a transbrake this year and I knew the 7.5" ring gear wouldn't take more than 1 hit.
Cheapest way? Find a center section with gears and carrier that you want to use from a local sale. Chances are the carrier will be 28 or 31 spline. You can buy a 9" aftermarket housing and axles for around $900. Make sure you specify the spline count needed when ordering. Install some brakes on the new housing and install it.
How much you pay for that center section will depend on what you want in it. 3.73 type gears and a posi would be the typical choice.
You could really cheap out and pull a ford truck 31 spline open diff center section out of the junk yard for next to nothing. It'll have 2.xx or maybe 3.xx gears. Pop it into the $900 housing and you have a 9" under the car for cheap. Later on when you have more money buy a posi and gears for it.
Old Mar 16, 2002 | 04:21 PM
well what is the actual part that wil break with 500 HP on a 10 bolt?
Old Mar 16, 2002 | 05:07 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Assuming everything else has been changed to take the abuse such as aftermarket 28 spline axles, solid diff cover with bearing cap supports, welded axle tubes, solid crush sleeve, the weak link is still the tiny teeth on the ring and pinion. Everything else just helps keep it all together but there's nothing you can do about the ring and pinion. If they make them, buying a set of Pro gears for a 7.5" will be the way to go but a 7.5" is NOT a performance diff so good performance parts are hard to find.
Shocking the diff will break teeth off very quickly. Don't use a transbrake, don't do a high rpm clutch drop, don't use NOS off the line and a 7.5 could probably run 10's.
Old Mar 17, 2002 | 12:15 PM
well how much would it cost me to do all that stuff you said to my 10 bolt. It still sounds very expensive, and i saw a 12 bolt for a camaro for like $1600.
MY87LT
Aftermarket Product Review
Jun 7, 2016 09:47 PM
Numbah-1
Sep 12, 2015 08:57 PM
Jlanz55
Sep 6, 2015 07:28 PM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
