World Class T5 tranny...
Old Mar 16, 2002 | 05:54 PM
Cruz'N Bruz'R's Avatar
Car: 87 Iroc Z
Engine: 383ci.
Transmission: WC-T5
I've heard this World Class term mentioned a few times on this site, and I have no clue what it means or is. Is it a special option tranny or what? How could someone tell if their tranny is a "world class"?
Old Mar 16, 2002 | 08:45 PM
v8powr's Avatar
I believe camaros and birds used wc after 87....i could be wrong. i think it means better syncronizers and they can handle a little more torque. I,m sure someone else will post soon with more info.
Old Mar 16, 2002 | 09:56 PM
iroc22's Avatar
I am pretty sure '88 and up V8 thirdgens got the world class T5's. I believe they just had better syncronizers as mentioned above and were rated at 330ft/lbs of torque while the regular ones were 300ft/lbs
Old Mar 16, 2002 | 10:04 PM
Car: 87 Iroc Z
Engine: 383ci.
Transmission: WC-T5
Oh well, thanks for the info, but I think I'm screwed either way.
Old Mar 18, 2002 | 09:06 AM
Steve89GTA's Avatar
The T5 World Class started out in 87. It uses a Dexron III type lubrication system and features much better lubricating properties than the standard T5 available in previous models. The synchros are beefier and the bearing are tappered instead of the standard $hit. It will last longer.
Old Mar 18, 2002 | 03:43 PM
v8powr's Avatar
not tht Ive looked very hard but where do you put the fluid in on that tranny?
Old Mar 18, 2002 | 03:49 PM
Steve89GTA's Avatar
I remove the shifter and pour it in from the top. Works great! I used to use an old fuel pump and rubber tubing to pump it into the upper plug on the passenger side.
Old Mar 18, 2002 | 06:07 PM
v8powr's Avatar
How can I check the level? I havent noticed a stick unless im just missing it.
Old Mar 18, 2002 | 06:14 PM
Tony89GTA's Avatar
Car: 89 GTA
Engine: 5.7L Supercharged
Axle/Gears: Moser 9" 3.70
GM switch to the WC T5 in 88, I think the mustangs got them in 85.
Rated Strength
non-WC, 2.95 low: 275-280 Ib-ft
WC, 2.95 low: 305 Ib-ft
Ford Racing "Z" box: 330 Ib-ft
Old Mar 18, 2002 | 10:30 PM
Steve89GTA's Avatar
No, there's no stick. The proper way is to remove the top plug on the passenger side. While filling, when fluid reaches that level (the upper plug), plug her up and you're done. make a note of how much fluid you used (remember, A/F only!!) that way you can change it faster and easier the next time. I change mine every 10,000km's but then again, I'm overkill and always have been.
Old Mar 19, 2002 | 01:25 AM
v8powr's Avatar
thanks alot steve. maybe someday ill aquire some vast knowledge so i can help others out as well as you guys have helped me.
Brandon
sLoW'n'StEaDy
Aug 31, 2007 09:24 AM
3rdGenSS
Feb 6, 2005 04:29 PM
CloudIROCZ28
Sep 30, 2001 09:07 PM
