rear end weldup
rear end weldup
I know it's bad and wrong but has anyone done this the car budget is gone and I need traction its eather weld up the spider gears on a 3.23 open rear or put a posi unit with 2.73
the car is driven almost every day but for fun not as means of transportation
Car: Camaro
Engine: Carbed L98
Transmission: TH350
I think a by adding a spacer to the 3.23 gear it sould fit the 2.73 carrier.
I may be wrong. I am going from a 2.73 posi and buying a 3.73 gear for this unit. The gear I belive will be thicker for the 2.73 unit. I figure that a spacer on the 3.23 would work for you.
If Im wrong someone help this guy and set me straight. I dont want to stear anyone wrong.
Car: 1987 Camaro Z-28
Engine: 6.3L Victor EFI
Transmission: Tremec TKO 600
Axle/Gears: Moser 9"/4.11 Trac-Lok
I did the spacer in my old 10 bolt rear & it worked fine. I went from 2.73 to 3.73. Welding the spider gears is a bad idea especially on the street. Remember you have to go around corners this stresses the axles big time on welded or spooled rears.
hectre13
Dec 11, 2023 08:14 AM
hectre13
Aug 26, 2015 08:17 AM
AkDrifted
Aug 17, 2015 07:45 PM
