When is a new flexplate needed?
Old Mar 27, 2002 | 07:30 PM
BuckeyeROC's Avatar
Car: 2015 Camaro Z/28 & 2013 Super Bee
Engine: LS7 and 392 HEMI
I have a newly built engine (in my sig), and a new Pro-Built Street/Strip tranny with a Vigilante going in soon. Is the stock flexplate going to be ok? When should it be replaced or does it need to be unless something catastrophic happens to it? If I need one, what brand and number of teeth, etc. should I get?
Old Mar 29, 2002 | 08:45 PM
BuckeyeROC's Avatar
Somebody must know
Old Apr 7, 2002 | 05:44 PM
BuckeyeROC's Avatar
ttt
Old Apr 7, 2002 | 08:01 PM
Ricktpi's Avatar
Car: 1987 Camaro Z-28
Engine: 6.3L Victor EFI
Transmission: Tremec TKO 600
Axle/Gears: Moser 9"/4.11 Trac-Lok
Is your old one showing cracks or have elongated bolt holes ? If not use it unless you need one with SFI certification. The # of teeth relates to how your starter mounts, if it's the original block, use the same amount of teeth as your original flex plate has & use the same style starter also.
Old Apr 9, 2002 | 05:40 AM
BigH's Avatar
Here is what happens if you dont inspect the flexplate
I let the noise go on for sometime before replacing,
it is fairly easy to inspect for cracks look from edge to
center of flexplate.
John 89GTA
Attached Thumbnails When is a new flexplate needed?-johnnie-lees-flywheel.jpg
84z96L31vortec
Aug 20, 2017 12:16 AM
IROCZ1989
Jan 24, 2016 03:55 PM
kitt23
Exterior Parts Wanted
Aug 15, 2015 12:37 PM
86camaroman201
Fabrication
Aug 11, 2015 10:39 PM
GEmrsn
Interior Parts Wanted
Aug 8, 2015 03:15 PM
