When I turn my steering wheel, I hear a click...
Old Mar 31, 2002 | 12:35 AM
ChevyLuva3's Avatar
This has not happened since I bought the car, until around a month ago till now. It doesn't happen on all turns, it usually happens when the wheel is straight (car going straight), then when I go to turn it, theres a click I feel through the steering wheel. It usually clicks when I pass the "straight" position of the wheel. Its just one click, just one thing though now I can kinda hear it outside. When I back up in reverse say out of a parking spot. And I go to drive off, and turn, I hear click, a metal click, almost like a busted tranny mount, except its a quicker click and its not that loud. Obviously the busted tranny mount can be felt where the shifter is. But I feel and hear it on the steering wheel. And I also hear it outside sometimes, cuz it depends whether I have my music up or not. What could it be??
Old Mar 31, 2002 | 05:23 PM
Eightyninef's Avatar
intermediate steering shaft
Old Mar 31, 2002 | 09:24 PM
ChevyLuva3's Avatar
Is it serious? Whats up with it?
Old Mar 31, 2002 | 11:26 PM
CheezX's Avatar
Mine did that and the steering wheel was loose. I just tightened the nut and it went away. Try wiggling the edge of the wheel, if it moves then that's probably it.
Old Apr 1, 2002 | 05:47 PM
ChevyLuva3's Avatar
Hmm I'll check that out, thanks.
Old Apr 2, 2002 | 11:01 PM
IROCZ88's Avatar
Mine does that too, and it's not a loose steering wheel.
Old Apr 3, 2002 | 12:11 AM
ChevyLuva3's Avatar
Yeah, damn, forgot to check, hope I remember, and yeah my steering wheel isn't that loose either, actually steering it is pretty damn tough, I thought maybe thats how our steering system was made. Ya def need muscle to turn.
Old Apr 3, 2002 | 07:02 AM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
My GTA and IROC both do it, and neither has a loose wheel. My steering with both of them is very tight and not at all sloppy, but I get the little "click" that I can feel right as I pass center with the wheel. Drives me nuts.
My cherokee did it very badly and it was because a pivot ball on one of the steering components was shot. I just can't remember what piece it was because I didn't change it myself.
Old Apr 3, 2002 | 08:18 AM
PonchoTA's Avatar
Careful!!
Mine was doing that and I found out that the frame was cracked where the steering box mounts to the frame.
This is a very common problem on these cars. There's even a factory brace to fix it. It will retrofit on earlier cars too, the bolt holes are already in place!
Must get the frame welded to stop the splitting, then add the brace!
HTH,
Poncho
Old Apr 3, 2002 | 09:11 AM
IROCZ88's Avatar
I checked and there's no sign of any cracks around my steering box. It's just a real tiny click, almost seems like it's supposed to be there.
Old Apr 3, 2002 | 10:42 AM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
That crack is supposed to be between the box and the frame, right? Could it be seen without removing the box?
Old Apr 3, 2002 | 11:41 AM
ChevyLuva3's Avatar
Re: Careful!!
HTH,
Poncho
Sorry for sounding like an idiot but.. wheres the steering box located?
Old Apr 10, 2002 | 08:22 PM
Jim85IROC's Avatar
Just follow the steering column down to the end. The steering box is what the steering column disappears into. It's bolted to the subframe.
Old Apr 10, 2002 | 09:29 PM
ChevyLuva3's Avatar
OK.. will check. But what am I looking for? Would the box be able to move off the frame or something? Thanks!
Old Apr 11, 2002 | 06:55 PM
ZZ28ZZ's Avatar
Car: 82 Z-28
Engine: 383 TPI
Yes, the steering box bolts to the subframe. May need an impact wrench to remove the big nut holding the steering arm onto the output shaft. Then again, you may not need to disconnect the steering arm if all ya wanna do is look behind the steering box.
Another thing you could do is get a helper to turn the steering wheel abt 1/8 turn from center and back again quickly(with eng off and key on) while you look under the hood and under the front end. If there's any slop anywhere you should be able to see it. May need to wipe the grease and grime off all the mechanical connections and have a good, bright light. If you see any slop, it's too much.
On my Z, I found the drag bar (the long bar that goes from one side of the car to the other) pivots, where the tierods (the rods that go to the wheel spindles and have an adjustable length, like a turnbuckle) connect, were worn out and had slop. I didn't get a click, but got a bad shake when braking. Oddly enough, it drove pretty well.
You say steering is tough. Shouldn't be if you have power steering. Surely your car has power steering. Right?
Old Apr 11, 2002 | 08:44 PM
camaro6spd's Avatar
that brace is the 'wonder bar' get it ne way, much tighter frontend.
Old Apr 11, 2002 | 11:16 PM
ChevyLuva3's Avatar
Yeah I have power steering. Maybe it doesn't work?? I mean its not a struggle to turn it, its just a lot tougher then the average car. I think it would be more fun if the wheel was looser. Sometimes I feel my chest muscles contracting (steering with only left hand), when I have to turn, I don't remember needing that much strain for other cars. Ya should see me with other cars, I'll go to turn 90 degrees and practicly make a 360, cuz of all the effort I put into steering it, due to being used to my car.
..I have an aftermarket steering wheel, I think B&M? I can't remember. But its a three spoke, Y-design, with three holes in the chrome spokes. Maybe that has something to do with it. The prev owner installed the wheel, maybe he did bad job??
Thanks for the help!
Old Apr 12, 2002 | 12:36 AM
ZZ28ZZ's Avatar
Car: 82 Z-28
Engine: 383 TPI
If it's a lot easier to turn the wheel with the eng running (while parked) than with eng off and it dosen't make a lot of noise, it's probably OK.
If it's not working, it's a serious struggle to turn when stopped.
A smaller diameter steering wheel will require a bit more effort, but not all that much. I put on a 13" steering wheel (Grant). It steers real fast now; almost too fast at high speed.
Can you tell if the "click" is coming from the inside or outside?
If it's on the inside, it may be part of your turn signal canceling mechanism. That's what turns off your blinker after you make a turn and straighten the wheel.
Regardless, it's still not a bad idea to crawl under the front end and watch everything operate as I mentioned previously.
backtothe80s
Sep 5, 2015 12:39 AM
Keiffer76
Car Audio
Aug 9, 2015 11:37 PM
Fronzizzle
Aug 9, 2015 01:15 PM
mustangman65_79
Aug 9, 2015 03:00 AM
johanlindgren
Wheels and Tires
Aug 6, 2015 03:32 PM
