Tranny doesn't downshift??HELP!!
Old Mar 31, 2002 | 09:28 AM
iroc420's Avatar
If I start driving at normal speeds then floor the car the car doesn't down shift. I adjusted the tv cable. Should I replace the damn thing?? Time for rebuild??I need help.
Old Mar 31, 2002 | 05:08 PM
Pro Built Automatics's Avatar
If you just want to solve this problem, I would install the Trans-Go Shift kit (Green & White box), this will solve the sicking TV valve and will make the TV calbe sensitive to adjustments as to down shifting & upshifting. This kit can be easily modified to HD specs. Along with this if you want it to be HD would be the larger boost valves & Corvette servo. Let me know if I can be of help?
Old Mar 31, 2002 | 05:39 PM
Gunny Highway's Avatar
Car: 91 RS
Engine: 350 TBI
What are HD specs?? And what does the TV cable do? I see people mention it from time to time, but I have no idea what it does, or lack there of. Is there something wrong with the original setup of it or something? Or does it just brake a lot?
tyeo098
Nov 30, 2015 06:27 PM
GouldyGTR
Sep 7, 2015 09:05 PM
Stryker412
Sep 7, 2015 09:11 AM
apie2546
Sep 5, 2015 07:40 PM
IROCZ1989
Sep 4, 2015 11:54 AM
