servo replacement....
Old Apr 3, 2002 | 03:13 AM
PPonU4Me's Avatar
When replacing the servo, does the tranny have to be lowered slightly to allow the shaft and piston to come out without hitting in the tunnel, or is there a trick to taking it out that I don't know. I have the assembly from the spring and e-clip forward out, but need the rest.
Old Apr 3, 2002 | 04:42 AM
transfixleo's Avatar
I unbolt the crossmember and push the tranny to the side for clearance.
Old Apr 3, 2002 | 08:29 AM
Gunny Highway's Avatar
Car: 91 RS
Engine: 350 TBI
I saw a tech article about how to do it w/o moving the tranny, I'll see if I can find it for you.
Old Apr 4, 2002 | 02:25 PM
fireturd350's Avatar
Car: '90 Formula 350
Engine: 383 SBC
Transmission: ProBuilt S/S 700-R4 & ACT 9" Stall
Axle/Gears: 10 bolt 3.23
Yeah, I've recently decided to put a corvette servo in my car. I got the cover and 4th piston, e clip, washer, spring, and part of the housing out no problem, but I ended up having to take out the trannie mount and loosen up the crossmember some and swing the trannie driver side a little bit to clear for the shaft to drop out. It was kind of a pita, but it had to be done.
Old Apr 4, 2002 | 11:28 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
I was about to post the same question. Now I know what I've got ahead of me tomorrow evening.
Removing the distributor cap is a bit of a pain with that SuperCoil on there...
Frozer!!!
Jan 19, 2024 04:55 PM
lt1z350
Sep 29, 2015 01:50 PM
Dragonsys
Sep 25, 2015 03:51 PM
italiano67
Sep 22, 2015 08:42 AM
scottmoyer
Sep 7, 2015 07:06 PM
