Whats the fastest everyones run with a 7.5 10 bolt??
Car: 91 Formula, 79 Trans Am, 72 LeMans
Engine: 305 TPI, 6.6, 350 Pontiac
Transmission: T5, 3 speed, TH350
Just curious cause I am going to use mine until I get the NOS in which may be next year. Anyone gone 12's or faster?? Thanks
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
My best times (below) are with a 7.5" ring and pinion 10 bolt. Nothing else inside the diff was stock. I just switched to a 9" this winter because I also went with a transbrake.
Ok, that makes me feel a little better, if you didnt have problems I shouldn't. I mean this isnt a full out race car, may see the track 2-3 times a year with a couple passes each time.
Car: 1987 Camaro Z-28
Engine: 6.3L Victor EFI
Transmission: Tremec TKO 600
Axle/Gears: Moser 9"/4.11 Trac-Lok
Mine runs low 13s & some high 12's with the stock rear, never had a problem. Swapped in a Moser 9" & sold the 7.65 to a guy, he did two burnouts & burned the posi.
Car: 87 IROC L98
From your sig I don't think you'll have anything to worry about. Manual transmissions are a lot harder on the diff from high rpm clutch drops. That shock is what breaks teeth off.
You can always upgrade to aftermarket 28 spline axles and carrier with a solid diff cover with bearing cap supports to make it stronger.
Camrs89,
I don't think the guy ever took it to the track. He did this on the street. My old rear (7.625) was completely rebuilt except for the posi. It had 130,000 miles on it when it was rebuilt.
Car: 89' T/A, 00' Firehawk
Engine: 406 Roller
Transmission: TH700R4 w/2800 stall
Axle/Gears: 3.23 Posi
that makes me kinda feel better to know some people are running 12's on them. i was wondering if it would last behind my 406. I am planning using a rearend girdle, weld the axle tubs and use redline gearshock lube. I also have heard to run a solid crush sleeve, has anyone else heard this? any other tricks or tips to make the rearend stronger? thanks lll jay
Car: 2015 Camaro Z/28 & 2013 Super Bee
Engine: LS7 and 392 HEMI
hectre13
Aug 26, 2015 08:17 AM
knight72
Aug 10, 2015 09:32 PM
