? about 9-bolt to 4th gen. 10-bolt
Old Apr 3, 2002 | 06:58 PM
rdog30's Avatar
Car: 85&95 Trans am
Engine: 85-LT1 95-LT1
Transmission: 4l60e & 4l60e
Axle/Gears: 3.23 & 3.23
I've got the 9-bolt disc now and I'm going to get a 10-bolt out of a totaled 98 v-6 camaro. It's disc and has 3.23 gears, but is not posi.
1st ?) If I buy the posi unit from slp will all I have to do is swap the carriers out? Put all the other stuff back in?
2nd ?) I don't have anti-lock brakes, but I'm sure the 4th gen does any concerns here?
3rd ?) Anything else I should know about or watch for?
Thanks for the help
Old Apr 3, 2002 | 09:17 PM
rdog30's Avatar
Car: 85&95 Trans am
Anyone?
Old Apr 3, 2002 | 10:15 PM
Dyno Don's Avatar
Transmission: Tremec T-56
Axle/Gears: 12 Bolt 3.73
Why would you want to remove a 4.10 9-bolt and replace it with a 3.23 open 10-bolt?
Old Apr 4, 2002 | 12:01 AM
rdog30's Avatar
Car: 85&95 Trans am
For starters the 4.10 gears in a 305 just don't work, gas sucks. Second the posi carrier is slipping and I just found out today that there is metal shavings in the fluid. 10-bolt parts=cheaper compared to 9-bolt parts. And the fact that I have 4th gen wheels on the car. That means i can do away with the spacers.
Anyone want to help me out?
Old Apr 4, 2002 | 11:37 AM
rdog30's Avatar
Car: 85&95 Trans am
Hello! anyone out there?
Old Apr 4, 2002 | 12:08 PM
Ricktpi's Avatar
Car: 1987 Camaro Z-28
Engine: 6.3L Victor EFI
Transmission: Tremec TKO 600
Axle/Gears: Moser 9"/4.11 Trac-Lok
You will have to setup the gears when you swap in the posi. 2-3 hour job if you know what you are doing. 4th gen V6s don't have electronic traction control. 98 & up f bodies w/o trac control all use the same axles. Pretty much a bolt in.
Old Apr 4, 2002 | 08:41 PM
rdog30's Avatar
Car: 85&95 Trans am
Thanks for the help man. I can't wait to do this swap because my 9-bolt is humming really load now.
MoJoe
Members Camaros
33
Feb 6, 2025 09:47 PM
Spyder_TheGamer
Oct 2, 2015 12:25 PM
Agent507943
Firebirds Wanted
Oct 2, 2015 07:18 AM
Dragonsys
Sep 25, 2015 03:51 PM
Nikole
Sep 24, 2015 08:12 PM
