welding up the 9 bolt carrier!! All with experience please reply!!!!!!!!!!!!!
Old Apr 3, 2002 | 10:14 PM
firepheasent's Avatar
Im not a youngen and know the downsides to doing this, but the problem is that I have a 9 bolt rear with 3:45 gears w/worn out posi. A new 9 bolt carrier is 750-1100 bucks F@#K that .So untill I can get the funds to get my 9 INCH rear this will have to do. Has anybody elese done this on their 3rd gen and if so give me some overall details on your experince.
Old Apr 3, 2002 | 11:20 PM
88 427 Camaro's Avatar
Car: 88 Camaro
Engine: 427 BBC
Transmission: T400
Ummm, you're looking in the wrong places then. I offer brand new series 3 posi carriers for 9 bolts for 445. Even less if you have a core. I also offer gear ratios to 4.10 (actually, 5.13, but you'd better bring your visa card). All the info is at www.9bolt.com
PS Yes, I've welded spider gears (actually pinion gears) together. If you really want a locked rear end, I also have mini spools for the 9 bolt.
Miles
www.9bolt.com
Old Apr 5, 2002 | 04:26 PM
Momar's Avatar
actually, depending on how bad your posi is, there is a tech article on this site on how to shim the 9 bolt posi. This tightens up the posi so it works like new again.
Old Apr 6, 2002 | 01:23 PM
Christobal's Avatar
How much for the 9 bolt spool?
Old Apr 7, 2002 | 12:11 AM
Car: 88 Camaro
Engine: 427 BBC
Transmission: T400
Currently only mini spools are available. A spool or mini spool is not recommended for street use and will require aftermarket axles (factory axles will not last). If you are still interested in a mini spool, email me and I'll work up a price.
Miles
www.9bolt.com
hectre13
Dec 11, 2023 08:14 AM
Terrell351
Jun 13, 2021 01:13 PM
hectre13
Aug 26, 2015 08:17 AM
knight72
Aug 10, 2015 09:32 PM
