Which wire is powered?
Old Apr 6, 2002 | 09:39 AM
eric17422001's Avatar
Car: 3
Engine: inboard
Transmission: underfloor
I have a 700R in an S-10 swap, and just use a toggle switch to power the lockup manually. It has been awhile since I pulled my old trans and I need my memory refreshed. Is the outer front pin the one that gets powered?
Eric
Old Apr 6, 2002 | 10:44 AM
five7kid's Avatar
Transmission: 4L80E/4L80E
See https://www.thirdgen.org/techbb2/sho...threadid=97795 - been going through that myself.
I can't go out to the garage and look right now, but I believe that's correct. If you have a multi-meter, check between the various contacts and ground - the correct circuit should be open to ground. But, depending upon the type, the 4th gear circuit could either be zero resistance or open to ground. The resistance between the solenoid power and return should be between 20-30 ohms.
The return pin should be the one by itself.
Jeremys87
Jul 14, 2022 09:08 PM
Bert87
Aug 23, 2015 03:50 PM
Rakim_RS25TH
Car Audio
Aug 20, 2015 06:22 PM
stalkier
Aug 13, 2015 12:59 PM
ZsTransAm
Aug 11, 2015 07:30 PM
