kaboooom! bye bye 200c
Old Apr 6, 2002 | 06:59 PM
EvilCartman's Avatar
Car: '82 Z28
Well, the transmission finally let go today in a big way. I was on my way home, just pulled out of a parking lot, went full throttle untill boom! (about 2 seconds on the gas pedal WOT) Tried to slow to make a turn onto my road but of course when you have transmission fluid on your rear tires, that's not easy to do. Slowed down enough to make it into a parking lot and got a tow home. The pattern on the road makes it look like there's a hole in the torque converter. Did the mighty 305 just have too much for it? LOL if you want, give me your thoughts on what let loose. BTW, it's been shifting kind of bad on the 1-2 shift, sort of lazy.
edit: it also broke the plastic cover in two, you can just see the edge of it in the picture.
Old Apr 13, 2002 | 09:29 PM
Car: '82 Z28
Ok, finally got under the car again for a closer look to see what happend... I was unbolting the torque converter bolts when on turning to the second one, fluid started dripping out at a pretty good pace. I looked up and saw some shiny metal and felt a nasty ridge It's about an 8 inch or so rip/crack in the converter Also found some nuts and bolts loose from the rear end swap, should have known there was going to be problems because of the idiot who was helping me with that Anyway, the TH400 is getting rebuilt in a couple days to replace the TH200c :hail:
Old Apr 14, 2002 | 01:22 AM
ronterry's Avatar
Car: '94 Corvette
I've grenaded cases, sprags, races, shafts, and flexplates, but never split a converter !!! Good job !!!
It sounds like the converter balloon'ed beyond limits
Ron
Old Apr 14, 2002 | 05:36 AM
Car: '82 Z28
hehe thanks! Dropping the tranny later today and cutting open the converter on the CNC mill just for kicks. When that converter let loose, it sounded like a M80 going off
Old Apr 14, 2002 | 09:05 AM
JAY87GTA's Avatar
Did it ever rattle or make noises? I think mine is on the way out so I'm curious as to what yours did. Thanks
Old Apr 14, 2002 | 05:54 PM
Sitting Bull's Avatar
Car: 1986 Sport Coupé
Engine: 305-4v
Transmission: 700R4 and TransGo2
EvilCartman,
I want to get my engine up to the same parts as yours. What is you quarter mile time with that setup?
Old Apr 15, 2002 | 05:45 AM
Car: '82 Z28
Originally posted by Sitting Bull
EvilCartman,
I've never taken the car to the track but I'm guessing it would run mid 15's.
There wasn't any warning at all, no funny noises or rattles. I just went full throttle from a rolling start and a couple of seconds later, boom! sprayed the road with tranny fluid making it fun to try and stop
Old Apr 16, 2002 | 08:13 PM
BMmonteSS's Avatar
Car: 84' Monte
Transmission: 700-r4
Axle/Gears: ferd 9" posi 3.50 gears
Might want to check the motor out too. IF the converter balloned on ya it coulda taken out a thrust bearing.
Old Apr 17, 2002 | 12:22 AM
Car: '82 Z28
The motor seemed to run just fine, still holding steady at 60 psi for oil pressure. The converter slid back on the shaft after unbolting it so there wasn't any pressure on the crank at that time... If the motor does let loose down the road, I'm in the works on getting another one put together right now.
Old Apr 17, 2002 | 02:18 AM
Ward's Avatar
Car: 1988 GTA
Engine: 5.0 TPI
Axle/Gears: 9 Bolt, 3.45
now i remember why i want to put a standard trans in my car.
Old Apr 17, 2002 | 09:48 PM
Car: '82 Z28
I'd like to have a standard for my next car but this is turning into a drag car lol plus the TH400 should stand up well against the punishment of some BBC power Just priced one out today and damn, it looks like it might be cheaper than the 350 I was planning on building.
3rdgenparts
Exterior Parts for Sale
26
Apr 7, 2016 11:21 AM
NiG
Oct 11, 2015 08:42 PM
3rdgenparts
Aug 6, 2015 09:03 AM
TRAXION
Aftermarket Product Review
87
Nov 22, 2008 10:33 PM
burntblues
Oct 14, 2000 04:00 PM
