front end alignment??
Old Apr 7, 2002 | 07:59 AM
TransAm87's Avatar
Hey...i just put new rims and tires on my 87 T/A...I think my front end needs alignment but im not to sure? Even if it doesnt it wouldnt hurt to get it done correct? WHat do they do and how do they do it? Where can i get it done and what is the cost?
AJ
Old Apr 7, 2002 | 09:58 AM
82camaro's Avatar
Car: 82 camaro SC
Yes, have an alignment done. They will also check the front suspension for worn parts. If it's been more than a year since your last alignment, get it done. Don't be suprised if you need an idler arm or some other suspension part. In it's most basic form, an alignment makes sure the tires set up and down at the correct angle and the tires point straight down the road. A proper alignment will ensure the tires last as long as they should.
Old Apr 7, 2002 | 10:53 AM
TransAm87's Avatar
how much$
How much does this usually cost
Old Apr 7, 2002 | 07:24 PM
88 WS6 TransAm GTA's Avatar
Car: 92 Trans Am 'Vert
Transmission: 5 Speed
Alignments are usually $50. More if you need parts installed.
Old Apr 8, 2002 | 04:13 AM
91RS5spd's Avatar
Car: 1990 Camaro RS (IROC-Z Clone)
Engine: LO3
Axle/Gears: 3.08
If you run in to the same problem as me your idler arm will need to be replaced, I hear it's a common problem. That will add another $100 or so if you have some one else do it.
customblackbird
Aug 15, 2021 10:16 PM
Terrell351
Jun 13, 2021 01:13 PM
Amillionoh7
May 24, 2020 08:01 AM
bellez77
Sep 5, 2015 08:39 PM
johanlindgren
Wheels and Tires
Aug 6, 2015 03:32 PM
