How much power can a 9 bolt handle?
Car: 1989 GTA
Axle/Gears: 9bolt 3.27s
Thats the question. What kind of power are you guys putting to your 9 bolt? What does it cost to uprade it?
Car: 92 Trans Am 'Vert
Transmission: 5 Speed
9 bolts hold up pretty well. I dont have any numbers, but I can tell you that in 91k miles, 1 tranny, and 1 engine later, the origonal 9 bolt is still doin just fine!!!
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
The posi will wear out before the unit breaks. There are Turbo Trans Am owners in the 11's still using their original 3.27 9-bolt with no problems. Their only downside is the scarcity of them makes the pricer higher.
Car: 90 Formula, 02 ws6
Engine: 305 tpi, ls1
Transmission: 700r4, t-56
Axle/Gears: stock posi 2.73, 12 bolt with 4.11s
you can rebuild yours
look through the tech articals on this page you will find what you arew looking for
Car: 88 Camaro
Engine: 427 BBC
Transmission: T400
They can be shimmed to a point (GM procedure calls for a max shim of .010, anymore and the cones may be bottomed out.) I have new 9 bolt stuff available at www.9bolt.com
Miles
www.9bolt.com
Miles
www.9bolt.com
ambainb
Apr 25, 2016 09:21 PM
evilstuie
Apr 14, 2016 08:52 PM
