Mustang 5.0L T-5
Mustang 5.0L T-5
I would like to know if I can use a T-5 from a Mustang on My Z28. They are both borg-warner and the gears r the same. I was thinkin that all I need to change is the bell housing. Whats up?
Car: '86 Z-28
Engine: 355
I don't know if it would work i've been trying to figure that myself.
I do know that if it would work the only thing needed would be a different clutch disk. Our input (or at least mine) has 28 or 26 teeth on it and the ford has 10.
Car: Bee-Bowdy
Engine: blowd tree-fity
Transmission: sebin hunnerd
Axle/Gears: fo-tins
I think the pilot shaft is a different size too.
Other than the input shaft I think the inside is the same, flimsy one they used in the Mustangs.
Car: '86 Z-28
Engine: 355
The reason behind the Mustang trans. is that you can get a new one for $1100 that is underrated for 330 lb feet of torque. Where as, GM's stock T5 for a Camaro is 230 lb feet of torque. For some one on a very strick budget $1100 looks a lot better than the $2000 you'd pay for a Tremec or T56 that you have to spend more money on modifing to fit.
Car: 1987 Camaro
Engine: 1986 350
Transmission: T-5 NWC
it will be very nice to find out if someone did it and just how, 'cause i'm wondering that myself. if it works, will be a good and cheap approach to getting red of the crappy nwct5.
fernando.
fernando.
Car: 1988 GTA
Engine: 5.0 TPI
Axle/Gears: 9 Bolt, 3.45
It is possible to put a mustang gearbox in a thirdgen, you just have to put certain GM parts on/in the ford gearbox. Look at this website, it explains it in more detail. Note that this is not for a thirdgen, but from what I can tell the process would be exactly the same.
http://www.geocities.com/adria-amber/t5page.html
These are the years which i am almost positive are the same.
82-84 Mustang V8 has same T5 as 83-88 F-body V8 (non world class)
85-90 Mustang V8 has same T5 as 89-92 F-body (world class, little stronger.)
The 91-93 Mustang T5s are rated even stronger ( than our world class T5s so I am curious if its possible to use that in a thirdgen.
This chart might be helpful if someone knows any specs on factory F-Body T5s. If so then this chart should let you know what will swap.
http://www.fordmuscle.com/archives/2...p/index2.shtml
