700 and 350 differant lenghts?
Old Apr 11, 2002 | 09:50 PM
fattie92's Avatar
i have a 700r4 in my car right now,, but i might have to take it out due to tranny problems. i have a turbo350 avalible that i can use, but i dont know whats all needed for the swap. do i need a new drive shaft?? crossmember?? help please! i have a 84 TA
Old Apr 11, 2002 | 10:39 PM
fattie92's Avatar
ttt
Old Apr 11, 2002 | 10:41 PM
Mark A Shields's Avatar
Car: 99 Formula
Axle/Gears: 342
I do believe you need something to make it fit, but I forget what it's called.
Old Apr 11, 2002 | 11:27 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
A long tailshaft TH350, 9", will allow you to use the same driveshaft. If the TH350 has the shorter 6" tailshaft then you need a driveshaft from a 82-83 f-body that came with the TH200 tranny.
Pick up a tranny swap kit from TCI, Hurst etc. It will allow the tranny mount to line up and provide a place for the torque arm to attach.
There's a few other things required also but I'm sure the kits cover all of them. You need a vacuum line from the intake down to the tranny for the modulator valve. The bracket for the TV valve cable is different than the TH350's detent cable.
Old Apr 12, 2002 | 02:17 PM
fattie92's Avatar
what about all of the electronics?? doesnt the CC carb have a wire going to the ECM then to the tranny to tell it when to shift?? i know when i pulled the pan to the 700r4 there were wires all over the place!! also,, where can i find one of them kits?
Old Apr 15, 2002 | 10:38 AM
five7kid's Avatar
Transmission: 4L80E/4L80E
The wires are for two things: 1) for the tranny to tell the computer when it's in 4th; and 2) for the computer to tell the tranny to lock the torque converter clutch. If you don't have 4th or a TCC, you don't need the wires.
The TH350 torque arm mount kits are available from Summit & Jegs. If you want to do it right, get the crossmember/torque arm kit from Spohn.
Old Apr 15, 2002 | 02:45 PM
fattie92's Avatar
if i didnt have the wires, wont it send out a code to the ecm or something?
Jake_92RS
Jan 28, 2020 10:37 PM
Vintageracer
Jan 10, 2020 05:33 PM
fonzie85
Exterior Parts for Sale
39
Mar 16, 2016 07:07 AM
Mickeyruder
Sep 2, 2015 02:45 PM
crazynights
Aug 21, 2015 06:53 AM
