GP Lets get one rollin.
Old Apr 19, 2002 | 07:10 AM
Brian K's Avatar
We need a nitrous or some form of a GP...
Old Apr 19, 2002 | 10:44 AM
SAEspinz80's Avatar
or how 'bout a GP on cat.....like Random Technologies
Old Apr 19, 2002 | 12:45 PM
Brian K's Avatar
I was thinking something we all could benefit fomr like:
65.00 Lower Control Arms
or
65.00 Pan Hard Rod
Or
380.00 Dollar Nitrous Kit
Old Apr 19, 2002 | 09:22 PM
KED85's Avatar
Try timing chains, gaskets & water pump!
Distributor parts
Ignition-coils
FI cleaning! (Imagine all our cars broken at same time!)
Old Apr 20, 2002 | 06:27 PM
Joe_L's Avatar
Car: 1995 Z28
Transmission: Built 4L60E
Axle/Gears: 3.23's - Limited Slip
Distributor parts
Ignition-coils
That would be hilarious. Could you imagine the amount of threads titled My car won't start.
If were going to group purchase why not do something suspension wise. Polyurethane bushings and sub frame connectors...
Old Apr 25, 2002 | 02:13 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Poly bushings are something I might actually go for... I have too many things to do this summer, and nitrous isn't one of them!
I want to do the following (myself, not have a shop do it):
1. Rebuild a junkyard 2.8 and swap it in
2. Rebuild a junkyard 700r4 and swap it in
3. Replace the blown posi and put my '84/posi/disc axle back on
4. Weld in a new rear passenger quarter panel
5. Paint my car
6. Rebuild the front suspension with polygraphite bushings, and new "hard parts" (idler arm, center link)
7. Put in that quick ratio steering box from my basement
8. Box the rear control arms and panhard bar
9. Try to have a life while getting all this done
Last time I did all the bodywork and paint-prep work on my car, I disappeared from civilization for a month. It was "go to work, come home, work on car until exhausted, go to bed, repeat". It wasn't fun; I don't want to do that again. It was worth it, though!
Old Apr 25, 2002 | 02:35 PM
Project: 85 2.8 bird's Avatar
Car: 13 Ram 1500/ 78 Formy
Engine: 5.7 / 7.4
Transmission: 6sp / TH350
Axle/Gears: 3.55 posi / 3.23
TomP, if your not too busy, I'm going to be doing an engine swap soon.....
Old Apr 26, 2002 | 10:13 AM
KED85's Avatar
I'll be breaking in the 1970 LT-1 under the hood of my 1974 Corvette.
Need to swap that old mill out & in with the "new".
How about rebuilding my 85 Blazer 700R4?
And I do need body work, painting
Carpentry, too. I'm getting another house shortly.
It's warm and breeze in So Cal!
Old Apr 27, 2002 | 12:21 AM
CaliCamaroRS's Avatar
Engine: LH0 3.1L
I know exacty how you feel. I need to do so many things to my car. I just fixed my A/C and replaced my front spoiler. On my 3.4, I just now got the block 100% bare and ready for the hot tank. STILL trying to find tranny parts and the boneyards. All I do is wrench, wrench, wrench. After wrenching all day at work, I wrench. Sometimes I wrench on my lunch hour.
Oh, then the relatives come-a-calling....timing belt this, tune that.....the things we do for cars. *sigh* OK, enough of my bickering.
Old Apr 27, 2002 | 04:45 AM
coolrimsatleast's Avatar
Car: 89 f-bird and some others
Engine: 3.4
Things you own, end up owning you.
Old Apr 27, 2002 | 09:20 AM
KED85's Avatar
MAKE SURE YOU GET A DECENT RETURN ON INVESTMENT, TOO!
Either $$$$$$$$$$ or reliability.
Dan if ya need yard numbers or some machine shops, I can offer a few.
Give a shout!
Old Apr 29, 2002 | 10:21 PM
91FIREBIRDGT's Avatar
Car: 1991 Firebird
Engine: 3.1LV6
how about a GP on lowering springs for V6 thirdgens?
Old Apr 30, 2002 | 07:31 AM
SAEspinz80's Avatar
not a bad idea, but correct me if i am wrong.....they don't make them. if i remember right you need to buy a V8 set and cut the springs shorter in the front since the 6 is lighter than the 8.
Old May 1, 2002 | 10:05 PM
Car: 1991 Firebird
Engine: 3.1LV6
I've heard that Intrax does offer V6 springs for our cars but don't list them on any parts catalog. You can either call Intrax or Summit Racing to see if infact they do offer V6 springs.
Old May 1, 2002 | 11:21 PM
WaynesRS's Avatar
Someone get some of those EIBACH drag launch springs that are suppose to lower et's by .20 to .40 and go to the track and lets see how those puppies do !
Old May 2, 2002 | 09:31 AM
Camar_Hunter_c's Avatar
No intrax does not make them for V6 specific.
Old May 2, 2002 | 09:32 AM
I can get them for 190-200 I forget, I have not looked in my catalogs for a while... But I ccan get V6 Specfic 1" drop springs...
Old May 2, 2002 | 09:36 AM
SAEspinz80's Avatar
if those eibach springs hold up to their claims, that could be awesome. lower you 1/4 times would be great, and if they make the stance lower too its like two in one.
Old May 2, 2002 | 04:21 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
I imagine they'd be really loose on the street when taking corners... plus, I don't think we really need that with our V6's! (Not enough power) We'd probably be fine with just an airbag in the right rear spring (to prevent body twist).
blackstonea2
Apr 26, 2009 11:28 AM
FSTFBDY
Jul 22, 2003 10:55 PM
markus9
Nov 26, 2002 07:11 AM
