Hole in water pump?
Old May 9, 2002 | 05:07 PM
AmorgetRS's Avatar
Hole in water pump?
Hey guys, my water pump is leaking really really bad (6 gallons + a day). I went to replace it and I found that the water was coming out a hole in the bottom of the pump. It faces foreward toward the pulley, and looks like a stock GM hole... but water leaks out of it like crazy. Did something break inside the pump and therefor the water is leaking out a hole that is normally just open, or did something fall or a screw break out of the water pump?
Thanks!
Douglas
Old May 9, 2002 | 05:27 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Yep, somethings broken... that's a "weep hole", and water will drip from it when the pump's seal is shot.
Old May 11, 2002 | 09:29 AM
Horst's Avatar
Car: Firebird
Engine: 3.1 L
Transmission: auto
like TomP says, you need to replace your water pump, and the hole is always there but when water comes out that hole, your pump is gone
Horst
Old May 11, 2002 | 11:57 AM
AmorgetRS's Avatar
Thanks guys, I replaced it, no problems! Again, thank you for your help.
Old May 11, 2002 | 02:11 PM
Ovrclck350's Avatar
Sorry I didn't get to see this. Yah, the hole is GM. THey put it there as a way to basically say "Hey, your water pump is ****ed."
Glad you got the pump fixed though.
evilstuie
Jan 9, 2020 08:29 PM
Chuck84TA
Jul 15, 2016 09:05 PM
Bubbajones_ya
Aug 28, 2015 02:17 AM
1985chevydude
Aug 22, 2015 05:36 AM
Dialed_In
Aug 20, 2015 01:45 PM
