fuel leak
Old May 18, 2002 | 04:44 PM
kevinragman's Avatar
fuel leak
Please can anyone give me some info:hail: I have aquired a substantial fuel leak from the four pipes that come from the fuel tank, so bad in fact, that it is spraying fuel over the inner wheelwell and over the drivers side suspension and wheel. This only happens with the engine running because of the pressure. When the engine is shut of it still loses around a litre of fuel onto the driveway I really want to do this with out removing the rear suspension but, if it has to come out, it has to come out right?
Old May 18, 2002 | 05:00 PM
Joe_L's Avatar
Car: 1995 Z28
Transmission: Built 4L60E
Axle/Gears: 3.23's - Limited Slip
Welcome to the board.
I had a line rot off, the main line that is up next to the top of the tank. It would spray out a couple litres of gas in a few minutes.
I used a rubber hose to fix this and some clamps. (this is before I replaced my fuel tank and lines)
Can you see exactly where it is spraying from on the line. Can you see the lines crack or hole in it. Or is it up top on the tank, If so your in for some wild head aches.
Old May 18, 2002 | 05:54 PM
Thanks for the info. It was also my nightmare, I may just have to either change the tank or try to repair the old one somehow Again many thanks.
Infested
May 22, 2018 11:56 PM
bamaboy0323
Sep 3, 2015 06:07 AM
wayshegoes
Aug 17, 2015 12:00 PM
Kaweh
Aug 9, 2015 02:54 PM
